First post, by ClarkVent
I have several old DOS programs that use two graphics adapters at once. A VGA card is always used as the "primary" adapter and the Hercules cards as the "secondary". For instance, several old C compilers had the option of showing debug information on the second (Hercules) adapter.
How all these program work is simply by writing directly to memory >0xB000:0000.
Will this be supported in a future version? So for instance that the Hercules output is shown in a second window?
Reply 2 of 4, by ClarkVent
Too bad. There's a large amount of old business software for DOS out there that use this "dual" monitor setup. Like I said, many old C Developer Kits (like Watcom and Microsoft SDK) for instance, as well as some CAD programs.
Reply 3 of 4, by eL_PuSHeR
But DOSBox main target is games not applications.
Reply 4 of 4, by mr_bigmouth_502
I've actually heard that some DOS games (such as MechWarrior 2 and Rise of the Triad) actually support using dual monitors to display debug information while you play. I guess this would be a useful feature to put into a patch, just for people to try out.
