garrynichol wrote:Thanks for not explaining again. Is this just a guessing game?
I specifically wrote "like: set SDL_VIDEO_CENTERED=1"
That's how […]
That's how I always used to set the enviromental settings.
Maybe it's changed??
Please try to explain. Anyone can say google it.
I'm also having trouble understanding the help text files on the virtual os drive. Where is userconf????? What is it?
Is it a file?? I know it's a command line parameter but is it a file somewhere????
I've been reading replies to other newbies and you people are .....RFSAWAPUYA .
Please try to explain better.
I know you got it working now but are you daft on purpose? I'm not on Windows anymore and only vaguely remember where to set environment settings on windows xp, thus I wrote google it. Yes anyone can write google it but is it that hard to actually do exactly that? Google it? I'm not going to look it up just for anyone not able to use an internet search engine.
If you don't know what a word means ... Yes, right, GOOGLE IT. DBGL for example, the google result could have helped you faster than writing what it is and waiting for an answer...
Sorry for being too harsh, I know I am, but I'm fed up after a day with people not able to do simple thinking on their own.
Userconf is a parameter for the command line that will use an extra dosbox config ALONG with the default one. You need to make that extra config file yourself. Probably all written down in the readme. At least I was able to make sense of it when it was introduced with the last version.
