First post, by ConjurerDragon
- Newbie
I have installed Fantasy General and it runs perfectly.
However when I try to install the later released mini-campaign it fails.
The mini-campagin comes as FGEXP.EXE and if run expands into several files.
When running the Install.exe of those files the program asks where to install the mini-campaign of Fantasy General. Many years ago when I installed it I had to select the directory in which I installed Fantasy General but that won´t work now.
Trying it in Windows XP SP3 simply does nothing - I can select the right directory and when I select start the program ends and has done nothing to the Fantasy General installation - the game runs normally unchanged.
If I try to add it to Dfend Reloaded with Doxbox 0.74 and run it it always complains about the wrong parent directory whatever that means?
