Hi guys,
I'm trying to help my dad run a DOS program called TECPLOT that used to work on his old (busted) laptop, which we can't get working on anything else.
The program is used to graphically display data from a file. Using dosbox, we're able to start the program, but once we try to load up one of his files, it runs out of memory.
We've tried various combinations of xms, ems, etc and different cpu types and memory sizes, but no luck so far. One question: is the 64MB limit a DOS or just a dosbox limit?
Steps to reproduce:
Download and unzip: http://www.danilatos.com/dosbox_c.tar.gz
(Note: it's 50MB unzipped. Most of the contents aren't needed, but I didn't want to risk stuffing up the setup).
The "dosbox.conf" contains the current attempt, and an autoexec that will run the application (you might need to fiddle with it to make it actually mount the C: driver correctly though, depending on where you unzip it).
The problem should appear as an error message saying "OUT OF WORKSPACE"
If there's any more information I can provide to assist in diagnosing the issue, please let me know! Really appreciate any help!
