First post, by greyseer_thanquol
First - I realize that this is an alpha version and thus may simply be broken for my machine. But I'll ask anyway...
I'm trying to fix the sound for a number of old games on my machine (Win98, Athlon 2400+, SBLive! Sound card), which run fine otherwise. Following the Alpha install instructions I install VCREDIST.EXE fine, and reboot.
When I run INSTALL.BAT in the VDMSound dir, I get the following
out of environment space
Please make sure to have *SUCCESSFULLY* installed VCREDIST.EXE (and rebooted) or else this installation may fail!
Bad command or filename (x13)
Any help appreciated.
Avoid employing unlucky people -
Throw half the CVs in the bin.
Reply 1 of 2, by vladr
Hello,
You have too much stuff (like "VARIABLE=VALUE") defined in your AUTOEXEC.BAT, try to clean up some.
V.
Reply 2 of 2, by teamster1975
I think you need a command in config .sys like:
shell=c:\windows\command.com /e:1024 /p
This basically increases the environment size from the default 256 to 1024 which allows more SET commands.
