SimLife: No Audio
First post, by kawaiipikachu
Well I got the game at a Good Will recently alongside with SimFarm, Got SImfarm fully working not simlife.
I'm running Dosbox 0.74.
Here's the list of sound source it comes up with during ther install process:
NO MUSIC
PC Speaker
Ad Lib
Sound Blaster
Roland.
So Naturally I selected Sound Blaster from the list but when I go load the game up It produces no sound, not even PC Speaker sound.
Any Ideas to resolve the sound issue?
Reply 1 of 7, by bloodbat
Yes...change the IRQ in the setup program to match your dosbox.conf or the number you get by typing "set" (w/o quotes) in the blaster line the number after i.
Didn't work? Change in dosbox.conf the soundblaster irq to 5 from 7 or visceversa.
Reply 2 of 7, by kawaiipikachu
[quote=Bloodbat]Yes...change the IRQ in the setup program to match your dosbox.conf or the number you get by typing "set" (w/o quotes) in the blaster line the number after i.
Didn't work? Change in dosbox.conf the soundblaster irq to 5 from 7 or visceversa.[/quote]
No it didn't work & the setup doesn't include any IRQ input options which is strange.
Reply 3 of 7, by bloodbat
You tried both?
What are the contents of simlife.bat and are you running the game using that?
Reply 4 of 7, by kawaiipikachu
Yes I tried both & I loaded the game via the Simlife.bat & it's contents are"SML /640 S6"
Reply 5 of 7, by bloodbat
I think it might be missing a / behind s6 to make it /s6
That could fix your problem...check to see if files are read only, as install.exe should take care of that properly.
In any case try editing it to be /s6
Reply 6 of 7, by kawaiipikachu
It works.
Thanks for the help.
Reply 7 of 7, by bloodbat
Most welcome you are.
