First post, by Jan3Sobieski
Hey Everyone,
I've been doing some video card testing as of late and came to a weird conundrum you might say. I have several ATI Rage Pro Turbo cards that I have acquired and while testing them I decided to actually test each one as I figured some might be burnt or damaged. I have at least two Rage Pro Turbo AGP chipset cards, both with 8mb of vram, but it seems one on the bottom consistently scored better in everything I ran: from 3dMark99 to Quake 2, Unreal, Forsaken, Turok. If it was 0.1-0.5 fps difference, I could understand that, but for example: the top card scored 33.1fps on Turok benchmark (ran 3 times) and the bottom got 36.1 (ran 3 times again). I had even bigger fps variance in the other games, especially at the 640x480 resolution. Nothing else was changed. Used exact same drivers and testing environment (Abit BX6 rev 2.0, 1.1Ghz Pentium 3 @ 100Mhz FSB, MSI adapter, 256MB of PC100 RAM). If you look closely, the chips on both cards are exactly the same. Is it because the vram chips are different on both boards? If so, what's the difference and what can I identify it by other than physical size? Or is it because the bios chip being slightly different?
* the bottom board has two more vram chips on the back side.
Reply 2 of 17, by Jan3Sobieski
Mau1wurf1977 wrote:
Clocks might be different.
Is there a utility that displays the clock speed on older cards like these?
Reply 3 of 17, by leileilol
i know powerstrip can do it
Reply 4 of 17, by Jan3Sobieski
Well, just ran Powerstrip.
Both cards show:
Engine - 75Mhz
Memory - 100Mhz
No difference there
Reply 5 of 17, by Old Thrashbarg
The top card is one of the cost-reduced versions, I'm not sure if it was strictly OEM-market, but that's primarily where it was aimed. Smaller board, fewer components, etc. But, more relevantly, notice the slower RAM chips... the top one has 10ns chips versus the 8ns on the bottom one. Even if the clocks are the same, the timings probably aren't. I thought the core clock would be a bit slower on the upper one too.
Also, is it sure that Powerstrip can accurately identify Rage chips?
Reply 6 of 17, by Jan3Sobieski
That, I don't know. Both show, exactly: 99.76Mhz Memory clock, 74.81Mhz Engine clock.
It could be that Powerstrip just assumes all cards with this chipset run at this speed, however, I just noticed:
The top (slower) card is identified in windows as ATI Xpert 98 AGP 2x
The bottom (faster) card is identified in widows as ATI Xpert@Work AGP 2x
How can that be if they're both running the same exact chipset? The video card's bios?
Reply 7 of 17, by Tetrium
My guess is it's the VRAM.
Reply 8 of 17, by vlask
Might be memory timings. Upper one have SDR memory, other one has SGR memory. Or chip itself could be more optimized for sgr than sdr. And ofc powerstrip can be always wrong 😉
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 9 of 17, by Jan3Sobieski
Would this explain why the card is detected differently in windows?
Reply 10 of 17, by Tetrium
Possible, but not necessarily the case. It's also possible 1 is an OEM part and thus named differently.
My retro rigs (old topic)
Report spammers here!
Reply 11 of 17, by Old Thrashbarg
I'm pretty sure they're both SGRAM... I don't think the Rage Pro even supported SDRAM. The Rage XL did, but I think the Rage Pro was limited to either SGRAM or WRAM.
And yes, as I said before, the top one, the Xpert98, is a low-cost version aimed primarily at OEMs. I don't see what's so hard to understand about them being named differently... it's the same general idea as, say, a Radeon 9600 vs a 9600 Pro. Just because they have the same chipset does not make them the same card.
Reply 12 of 17, by Jan3Sobieski
I understand that, I guess I'm just confused by the fact that (unless powerstrip is wrong) they both have same clock speeds. In this case the card's bios' are different, one "knowing" the card has faster ram identifies it differently even thought they have the same chipset.
Reply 13 of 17, by Old Thrashbarg
There's way more to video cards than just clockspeeds. There's a lot to do with memory timings and such going on behind the scenes. Just like with any other RAM... PC133 at CL3 is going to be slower than PC133 with CL2.
And the BIOS on the video card doesn't "know" or "identify" anything. It's pre-programmed with certain settings, and it will operate only according to the set values. The BIOS on the top card is programmed with different settings than the BIOS on the bottom card... simple as that.
Reply 14 of 17, by swaaye
How about just benching the two in say Final Reality or Quake2 and seeing what results you get.
Reply 15 of 17, by Jan3Sobieski
Well, here are the results:
Top card:
Quake 2 Crusher demo benchmark
640x480 - 18.2
800x600 - 13.1
1024x768 - 8.7
Quake 2 Massive demo benchmark
640x480 - 22.4
800x600 - 15.4
1024x768 - 9.9
Final Reality score - 5.42
Bottom card:
640x480 - 18.5
800x600 - 13.3
1024x768 - 8.9
640x480 - 22.8
800x600 - 15.8
1024x768 - 10.2
Final Reality score - 5.75
Seems like the memory timings is all that's causing this. Mystery (if you can call it that) solved.
Reply 16 of 17, by Anonymous Coward
I'd like to point out two other differences. If you look at the circuit board on the bottom card, you can see the solder pads for optional memory expansion, and TV out.
Reply 17 of 17, by Putas
All Rage Pro are 75/100. The upper card really have SDRAM.
