First post, by EscapeVelocity
Should I get one? Or maybe use an LCD HDTV and really blow up the image size? Or get an older 4:3 aspect ratio LCD monitor as large as possible.
What were some of the most common, best reviewed monitors from the 90s?
Anybody have a 80s monitor?
If I get a CRT monitor should I get a later one, with high refresh rates, and multisync?
There also seem to be some early LCD 4:3 monitors that have a CRT monitor look to the front bezels. Like these 20 inchers...
I have sentimental attachment to Mag Innovision and Viewsonic.
However the NECs were always top rated. Mitsubishi and Sony and Ilo (as well as NEC) put out some of the hugely expensive graphics and design work monitors, late in the 90s and early 2000s.
Then there was KDS, CTX, Iiyama, Panasonic. Or you could get a Dell, Gateway, Compaq branded monitor. I have Gateway sentimentalities.
Any comments or reminisces, appreciated.
