First post, by tylerok
So I recently came across this game Are you Afraid of the Dark from the 90s.....and found an .iso for it. I'm using the latest version of DOSbox and my system specs are
Time of this report: 3/15/2011, 21:07:58
Machine name: TYLER-PC
Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.101014-0432)
Language: English (Regional Setting: English)
System Manufacturer: alienware
System Model: alienware
BIOS: BIOS Date: 03/20/08 Ver: 08.00.14
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 6400+ (2 CPUs), ~3.2GHz
Memory: 2046MB RAM
Page File: 2780MB used, 1552MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
DxDiag Version: 7.00.6002.18107 32bit Unicode
I open dosbox and run the following command lines
Z:\>mount c c:\games\
Drive C is mounted as local directory c:\games\
Z:\>imgmount d c:\afraid.iso -t iso
MSCDEX installed.
Drive D is mounted as c:\games\Afraid.iso
Z:\>d:
D:\>install.exe
the game installs fine but when it runs, the dosbox screen is kinda cut into rows and moving the icon between leaves an afterimage of the icon so the game is unseeable...though the sound comes through fine. Is there anything anyone knows I could do to possibly alleviate this? I'm mostly computer illiterate, but I learn quickly, so any help is greatly appreciated. Thank you.
Reply 1 of 2, by Jorpho
No no no no don't say that!!
There happen to be a bunch of threads on the subject already, for some reason. There was even one just last week!
Are You Afraid of the Dark- can't install to any drive
[SOLVED]Dosbox, Strange Video Problem
Are You Afraid Of The Dark on Vista
Are You Afraid of the Dark?: The Tale of Orpheo's Curse
Reply 2 of 2, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
