Fluidsynth soundfont patch
First post, by ykhwong
Due to some compilation issues in older patch(help using Fluidsynth patch with Dosbox 0.74 by clestrade), I renewed it against the current SVN of DOSBox.
You may use the latest version of Fluidsynth library. It works fine with some delays at startup even in Windows. Tested with SGM-V2.01.sf2 (about 250MB), one of the free soundfonts circulating on the web.
Set mididevice=synth and midiconfig= to your soundfont file.
mididevice=synth
midiconfig=SGM-V2.01.sf2
    dosbox-fsynth.diff
    14.83 KiB
    923 downloads
Reply 2 of 84, by ADDiCT
This is interesting! I have zero experience with FluidSynth, does it have any advantages/disadvantages compared to Timidity+? I'm currently starting Timidity+ each time before starting DOSBox (wouldn't want it running all the time and eating memory, as I need it only for gaming), so an integrated solution would be neat.
Reply 4 of 84, by ADDiCT
I've never had any lags with Timidity, can't say anything about its reverb (IIRC it's disabled by default, not sure), dunno how to duct-tape software and don't care about how a piece of software is "rated". I'd love to hear tangible opinions however (; .
Reply 5 of 84, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
There is also a nice patch in the tracker for OS X' coreaudio to load a different soundfont. Same patch also for Exult and I noticed that the same soundfont has more oomph with fluidsynth...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 84, by ykhwong
This is a patch of fluidsynth + timidity server backend(http://sourceforge.net/tracker/index.php?func … 551&atid=467234) for DOSBox.
You don't need timidity library at all but it only requires SDL_net. (It will not allow to use timidity directly.)
Reply 7 of 84, by ykhwong
The default gain setting makes the volume too low in DOSBox. To increase gain, add the following code to MidiDriver_FluidSynth::open().
		fluid_settings_setnum(settings,
"synth.gain", 1);
Reply 8 of 84, by truth_deleted
Updated the above patch for dosbox-svn code as of 1/11/14. Also, added several fluidsynth settings to patch so the midi output closely mimics the reference General MIDI devices (MS GS Wavetable and Roland SC-55). Strongly recommend this soundfont to accompany the patch: Scc1t2.sf2. Tested against several DOS games. Binary is available via the web link in signature.
    dosbox-fsynth-2.diff
    16.04 KiB
    248 downloads
    fluidsynth patch for dosbox-svn (1/11/14); requires fluidsynth library
Reply 9 of 84, by Dominus
DOSBox Moderator
I'm not really using it but a nice addition would be the possibility to stack several soundfonts. Exult has that option and through that you can achieve an instrument perfection that one soundfont can't give you 😉
Reply 11 of 84, by Dominus
DOSBox Moderator
E-MU?
Reply 13 of 84, by truth_deleted
Attached a test binary of dosbox-SVN+fluidsynth. Fluidsynth 1.1.6 was built by mingw32 (1/19/14), according to these instructions. It is dependent on glib and gthread libraries, also included in the attached archive. Since this was built by cmake, I had the opportunity to customize the build and exclude unnecessary dependencies. Recommend the Scc1t2.sf2 as an accurate soundfont. Other than choosing "General MIDI" in the game's options, two edits are required to your dosbox.conf file:
mididevice=synth
midiconfig=Scc1t2.sf2
Dosbox+fluidsynth was compiled for low latency MIDI audio and, in theory, should be ~1/10th latency of the built-in MS driver. This was tested with the above soundfont only.
    dosbox-SVN+GM.zip
    1.65 MiB
    282 downloads
    Test binary of dosbox-SVN+Synth (win32)
Reply 14 of 84, by truth_deleted
Attached a second test binary of dosbox-SVN+fluidsynth+REVERB effects. Used same build environment as above. Included reverb and chorus by two "switches" in the dosbox fluidsynth patch and modified a fluidsynth header file for satisfactory levels of chorus and reverb. Attached both patches below.
The default reverb and chorus settings are not ideal for gaming and there is discussion to correct these values: http://forums.scummvm.org/viewtopic.php?t=11632. Used these suggested values which are included in the attached fluidsynth patch.
Use the binary in the post above if these effects are not desired.
Edit: recommend WeedsGM3.sf2 for a soundfont, instead of the above Scc1t2.sf2. In SimCity2000, the latter soundfont has missing samples so certain sounds are missing from playback, while WeedsGM3 has these sounds. I don't believe this affects general music as much as the extra sound effects during gameplay.
    dosbox-SVN+GM+REVERB.zip
    1.65 MiB
    289 downloads
    Test binary of dosbox-SVN+Synth+REVERB (win32)
    dosbox-fsynth-2-REVERB.diff
    16.04 KiB
    220 downloads
    fluidsynth+REVERB patch for dosbox-svn (1/11/14)
    fluidsynth_REVERB.diff
    1.72 KiB
    216 downloads
    fluidsynth v1.1.6 REVERB patch
Reply 15 of 84, by bloodbat
Hi! Thanks for all the hard work on the fluidsynth patch, however, it drops instruments. Attached here are two sample files: both are recorded using your DosBox build attached in another post here; the first is the game's music playing through my X-Fi (the "win32" midi driver), the second is going through the build's built in Fluidsynth (the "synth" driver), as you can hear the Fluidsynth one is missing percussion. Both are using the same soundfont (SC-55.sf2). I built my own DosBox with VIsual C++ using your patch (and my own fluidsynth.dll) and the behavior is the same (even when altering parameters to suit Windows' default settings for fluidsynth).
I hope this can be fixed 😀
    fluidsynth.mp3
    742.65 KiB
    223 downloads
    Fluidsynth
    x-fi synth.mp3
    355.71 KiB
    208 downloads
    X-Fi Synth sample
Reply 16 of 84, by truth_deleted
That's a good test where you isolated the issue. I'll playback the samples tonight.
Edit: definitely missing instruments in the fluidsynth sample. 😀 Just to be sure, it would be worthwhile to test with the WeedsGM3 soundfont and possibly one other robust soundfont. I know your test showed that this shouldn't be the case since you controlled for a soundfont effect, but in the slight chance that the cause is an interaction between the soundfont and the software synthesizer. These soundfonts have produced different sounds in different synthesizers, although I can't recall that it would result in missed instruments.
Given another soundfont doesn't help, then would it be possible to upload a midi file which reproduces missed instruments?
Reply 17 of 84, by bloodbat
I'll capture the MIDI output and upload it, I'll also test with another soundfont, however, out of curiosity, I played the same sequence through the bass midi Windows driver and it works as it should using the same soundfont, which I'd say is pretty robust.
Edit: same behaviour with WeedsGM3...missing instruments...also with scc1t2.sf2.
Reply 18 of 84, by bloodbat
Heres a midi capture of the particular section, recorded while using fluidsynth with the missing instruments. If I play this MIDI using another player (say...foobar through bassmidi or the x-fi) it sounds as it should.
    sierra_000.zip
    3.16 KiB
    206 downloads
    A quick test midi
Reply 19 of 84, by truth_deleted
Thank you for testing! I'll see if I can find a simple solution to the missed notes.
Edit: it is very likely a bug in the fluidsynth patch for dosbox instead of fluidsynth itself. Confirmed by running the native fluidsynth binary here: Converting MIDI output to an audio file, which produces the proper instrument samples while using robust soundfonts. My best guess is that there is a problem in processing a midi event because the patch is incomplete. I wish I could isolate the midi events which correspond to the missing percussion sounds.
Also, I now recall this "missing instrument" issue while working on the patch, but I didn't debug beyond examining the original code for obvious errors in the workflow. There is an alternative patch here: FluidSynth MIDI driver, but it didn't compile cleanly, at least initially, so I used the above patch. In addition, both patches appear very similar, although with this missing instrument issue, it pays to try the alternative patch and confirm whether it somehow avoids this issue. Each handles the midi processing with a different API set (of functions), too.
Edit2: isolated the issue. It's the selected drum set. Confirmed by using "megamid" software in dosbox; the drums are missing unless the drum kit is changed by pressing the "." key. My best guess is that the drum kit isn't finding a proper default value upon playback of the midi file.
