First post, by bigbangnet
- Newbie
Problem: I will go straight to the fact. When I run dos games using dosbox the game starts to slow down...in some cases it stops. My pc is not freezing or hangsup. I need to "terminate" dosbox in order to regain control of dosbox 🤣.
The only exception to this is if I play doom 2 multiplayer. Also to note, if I play all those games in single player then ALL the games runs fine. This is the weird part.
Facts and info: I got an AMD quad core cpu with 4g of ram. I got a 1 terabyte HD with an audigy sound card. My bomb can run the latest games. So I don't think the hardware is not the problem. On the dosbox side, I can run redneck rampage and it's not stuttering, freezing, lagging ... no problem at all. I'm also using Windows 7 and my victim (test dummy, fresh meat, victim) has windows xp. We both got IPX installed... yup, my Windows 7 64bit got it too. and were using dosbox 0.74.
I started the ipx server on my side and he connected to me using my public IP address. Oddly enough, hamachi ip didn't work ???
When I play doom 2 with him on ipx then the game runs... a bit slow like the network bandwith was not enough but it's running. We tried Rise of the triad and that's where the game stopped working. The only image I could give you is if you tried to run doom 2 with 100 cycles in dosbox.conf...vveeeeerrrrryy slow.
What's going on ? Did I miss something ?
P.s: heres my dosbox.conf code...if that helps:
[sdl]fullscreen=falsefulldouble=falsefullresolution=originalwindowresolution=originaloutput=surfaceautolock=truesensitivity=300waitonerror=truepriority=higher,normalmapperfile=mapper-0.74.mapusescancodes=true[dosbox]language=machine=svga_s3captures=capturememsize=31[render]frameskip=0aspect=falsescaler=normal2x[cpu]core=autocputype=autocycles=autocycleup=10cycledown=20[mixer]nosound=falserate=44100blocksize=1024prebuffer=20[midi]mpu401=intelligentmididevice=defaultmidiconfig=[sblaster]sbtype=sb16sbbase=220irq=7dma=1hdma=5sbmixer=trueoplmode=autooplemu=defaultoplrate=44100[gus]gus=false
gusrate=44100gusbase=240gusirq=5gusdma=3ultradir=C:\ULTRASND[speaker]pcspeaker=truepcrate=44100tandy=autotandyrate=44100disney=true[joystick]joysticktype=autotimed=trueautofire=falseswap34=falsebuttonwrap=false[serial]serial1=dummyserial2=dummyserial3=modemserial4=directserial[dos]xms=trueems=trueumb=truekeyboardlayout=auto[ipx]ipx=true[autoexec]mount c g:\dosgamemount d d:\ -t cdromc:ipxnet startserver
