Reply 14 of 2743, by Tetrium
- l33t++
We need some more pics in here!!
As I was taking some pics for DonutKing, I took the opportunity to take some pics of the 2 retro rigs I used to play Unreal, so here they are 😉
The left box is my Super 7 Glide rig and the right one is my s370 Glide rig
The Super 7 retro rig:
FSP-made PSU (either 250W or 300W)
Gigabyte GA-5AX rev 4.1 (I think it's 4.1)
K6-3/400 AFR
256MB SDRAM PC-133 set as PC-100 cl2
AGP TNT2 M64 Vanta 16MB (Doesn't even have a heatsink. It's used for 2D only)
Voodoo2 12MB (has some slight artifacting, it always displays one block of the screen correctly, but with about half it's pixels dark blue! Didn't bother me in Unreal though and as it was otherwise performing just fine, I left it in there)
Soundcard can't remember if it was the Vortex or a Creative
Harddrive, somewhere around 6.4GB to 15GB I guess
Windows ME
This is actually my very first (and atm only) Super 7 rig but I really wanted to build one.
The case it's in has a story of it's own.
Years ago, back in my dark ages of endless dumpster diving (2002-ish), this was the very first ATX case I ever found that didn't have any missing parts. All other ATX cases I had found had either their drive cages removed or had one of their side panels missing.
This is also one of THE very first ATX cases to have ever made it to the market in The Netherlands. It's got "Designed for Windows 95" printed on one of it's front bezels on the front!
It's side panels are unusual in that they have these large plastic thingies in the side that you use to slide them in the "open" or "closed" position. Both side panels have this plastic grip thingy but the one on the motherboard side has always jammed a bit. No prob, as I only need to open the other side for accessing the insides of the case.
As a sidenote, it originally came with a Pentium 2, ASUS P7L97 I think. The board still functions and, even though I never used it in any rig of mine, I've always kept the board 😀
Because I wanted to avoid having any AGP related problems I at first intended to put a Voodoo3 PCI in there, but since a V3 is a bit overpowered and I had always wanted to try out teh Voodoo 2 for myself, I put a Voodoo 2 in there.
I used ME because it's what I use, it's basically my standard 9x OS. I know how it works, how to tweak it and how to keep it running. That, and my only ever own experience with 98SE turned out to be less then impressive.
It uses some standard cdrom drive and comes with a plain ol' boring 1.44 floppy drive.
I played through the entire Unreal 1 campaign on it for I can't remember how many days! The system has been remarkedly stable for me, not a single crash or lockup 😀
The s370 Glide rig:
FSP-made PSU 250W
Chaintech ??? i400BX Socket 370
Celeron 800 (yep...could've just put a Pentium 3 in there butteh...I wanted a Celeron hehe 😜)
256ish MB SDRAM PC-100 cl2 or PC-133 used as PC-100 cl2
AGP Voodoo3 3000
Soundcard can't remember if this one had the Vortex or the Creative
Some random cdrom burner or drive and another plain ol' boooring "a million a bucket" floppy drive
Harddrive probably 10 to 20Gigs
This rig was build after my 1st Glide retro rig.
As I had chosen the Voodoo2 in my Super 7 rig, I still was eager to try out a dedicated Voodoo 3 rig of my own.
I decided that a P3-1000 was a little bit overpowered for a Voodoo3 so I opted to try an Intel BX system.
As I prefer Socket 370 over Slot 1 I ended up using this i440BX Chaintech motherboard.
As I had no speedy 100Mhz fsb Coppermines at that time and underclocking one of my then few P3-1000's to a mere 750Mhz, I decided that I might as well put my Celeron 800 in there.
Another reason for me to stick with the 800Mhz Celeron is because I encountered a slight problem while mounting it's cooler: There are so many caps directly around the socket that it's impossible to mount anything larger then a Socket 7 sized cooler. I did try a smaller aluminium cooler but after a little while the heatsink became a little bit too hot for my taste.
Hence I went with the Celeron 800 (slower ones are 66Mhz fsb and I wanted 100Mhz fsb) and my only smallish copper cooler you see in the pic. I might have replaced the original Coolermaster fan with another Coolermaster fan to make it a bit more quiet.
However!...even though the little copper cooler cooled it much better, it's clip was blocking the memory slots and after a while I got tired of having to unmount+remount the cooler everytime I wanted to switch memory around. So I put the aluminium cooler back and mounted a neat looking LED fan which shines in 3 different colors yay! And it did fix the overheating problem well enough. (edit:the LED fan is actually an 8cm case fan. Thought I should point that out :endedit)
The 800Mhz Celeron is somewhat special as it is the very first Celeron to make use of the 100Mhz fsb. All previous Celerons were limited to a mere 66Mhz fsb which was fine for the PPGA Celerons, but made the first lot of Coppermine Celerons woefully underpowered compared to it's Coppermine brother (I always try to avoid the Celeron 566-766 ones).
That, and I actually wanted to use a Coppermine Celeron (I had already used a couple P3 Coppermines before and wanted to try out something new 😉 )
I used a different soundcard in this rig as I wanted to play through the campaign with a sound solution that was totally different from that of my other Glide rig.
Of course I installed ME on this computer also. XP seemed a bit too new for this one.
The case is a very nice one. Sturdy and good looking for an ordinary beige case.
No sharp edges on the inside, it was probably made by a quality manufacturer.
The only thing I dislike about the case is it's miniholes on the back for using the 8cm case fan, but other then that, I'm very pleased to own 2 of these cases 😀
I've played through the entire Unreal campaign again, only this time in hard.
Again, not a single crash or other ugly problems.
I intended to post some more and also different pics, but as my camera ran out of juice and it's too dark now to shoot a couple more, these ones will have to do 😀
I hope it was an enjoyable read! 😉
edit: Since PB decided to take a crap on us, I decided to re-upload at least some of the pics to Vogons directly, because missing pics in a picture thread just isn't really something many of us will probably like. Keep enjoying! 😀
