Retro Rig Photo Thread
Reply 1880 of 2713, by gerry
celeron_phreak wrote on 2021-02-21, 10:23:
And here is my recently assembled AMD K6-2/400 Build. I was saving this NOS AT case for something special to me. I like how it t […]
And here is my recently assembled AMD K6-2/400 Build. I was saving this NOS AT case for something special to me. I like how it turned out. The new Kingspao PSU that came with the case is working great too!
Specs:
CPU: AMD K6-2 @ 400MHz
GPU: Alliance Semiconductor AT-25 Voodoo RUSH
NIC: Compaq PCI 10/100 Ethernet
Sound: Creative PCI-512
HDD: Western Digital 40GB ATA-100
Optical: 12x LG CD-ROM
Floppy A: HP 1.2MB 5.25" Diskette
Floppy B: Hitachi 1.44MB 3.5" Diskette
PSU: Kingspao 200W AT/XT
Case: Unknown brand - Beige Mid Tower AT/XT
very tidy looking case for a nice late 90's era machine
Reply 1881 of 2713, by DundyTheCroc
Here is what I have at home:
1. My old 1998 PC with some uprgades (needs cleaning)
Windows98SE
Unknown BX440 MB
P3 450MHz CPU
2x256MB RAM
10.2 and 20GB HDD's
Creative Live 5.1 sound card
Acer 52x CD-ROM
Intel network card
Need to change video card, just recap broken Voodoo 3 2000 and it is alive again
45.3 KiB
2. 486/DX2 PC
Some history remarks: Two months ago I built VGA32 emulator (VIC20 and Altair 8800 emulation) for my 12 years old son. He was very happy, so I decided to find some real old hardware.
At work we have old building that was printing house long time ago. Now it is abandoned , but we have the keys and I started old parts hunt there 😀
So, the first prey was 486 PC:
Windows95OSR2
PC Chips M912 board with 256KB L2
Intel 486/DX2 CPU
512MB HDD
2x16MB RAM
Trident 9000 video 1MB
Later I added Yamaha 719 ISA audio and some CD-ROM
It was great fun to install Win 95 from floppy drive, never seen my son so happy 😀
57.38 KiB
Second raid in the old building:
3. Digital Venturis 575
Windows95OSR2
CPU Pentium 75MHz
RAM 8MB onboard (later added 4x8MB)
S3 Trio onboard (raplaced with S3 Virge/GX 2MB)
512MB HDD (wating for CF card with IDE adapter)
PC speaker sound (later added AWE64)
No CD-ROM (later added Asus CD Writer)
This PC is now my son's primary DOS gaming machine, sitting in his room. LCD used instead of the originall monitor.
196.39 KiB
4. Compaq AP550
Found it for 25 euro online.
Windows2000Pro SP4
1GHZ P3 Coppermine (raplaced with 2xP3 Coppermine 800MHz from old Compaq server)
4x128MB 800MHz RDRAM
32MB Matrox G400 (looking for some GeForce 2 Pro/GTS/Ultra)
2x18.2GB SCSI 10000rpm Compaq HDD's, again from the old server
Yamaha 724 PCI audio
CD Writer and VXA-320 tape drive
58.48 KiB
81.01 KiB
Reply 1882 of 2713, by RetroLizard
DundyTheCroc wrote on 2021-02-28, 13:09:
Here is what I have at home: 1. My old 1998 PC with some uprgades (needs cleaning) […]
Windows98SE
Unknown BX440 MB
P3 450MHz CPU
2x256MB RAM
10.2 and 20GB HDD's
Acer 52x CD-ROM
Intel network card
2. 486/DX2 PC
Windows95OSR2
Intel 486/DX2 CPU
512MB HDD
2x16MB RAM
Windows95OSR2
CPU Pentium 75MHz
4. Compaq AP550
Windows2000Pro SP4
These are all awesome builds!
Reply 1883 of 2713, by bjwil1991
Compaq Portable 1 (dual FDD) unit from 1983.
Specs:
NEC D8088D CPU
256KB on-board RAM
Compaq OEM Floppy Controller
Compaq OEM CGA card
Green Phosphorus CRT monitor
2 floppy drives (360KB) --> both need repairs
DFI MF-100 RAM expansion/RTC/Serial card (can also have a GamePort and LPT port) with 320KB RAM (needs work)
Quantum Plus HardCard 20 (boots up without issues after replacing the bad rubber with heat shrink tubing)
Western Digital WD8003E BNC/AUI-15 card
The keyboard needs repair as well (foam contact pads disintegrated) and I have the necessary parts to repair the keyboard and awaiting on the RAM for the memory expansion card, along with an XT-IDE w/ the CF card slot (single slot setup), rechargeable coin cell 3.6V batteries, and a CR2032 battery holder for the memory expansion card since it has RTC.
Once I get the floppy drives to work or connect my newly acquired 360KB drive, I'll be backing up every driver and file on multiple diskettes.
634.41 KiB
Reply 1884 of 2713, by mmx23
New 80 pin SCA scsi hdd mobile rack for my ALR Revolution 2x server. Is the most advanced hdd rack I ever saw, full aluminium, nice LCD display, temp, voltage, MTBF and fan monitoring. You can set thresholds for each and the rack will buzz when it will be reached. It has 2 cooling fans, the front one has an dust filter. By default only the back fan is working and the front one will start when the temp threshold is reached. You can even set the scsi ID from the panel.
Reply 1886 of 2713, by sigurbjornl
This is one of my two retro rigs and the one I just finished
Most of the system is a rig I built in late 98 to use as a FreeBSD server but I've made some hardware swaps while turning it into a Retro gaming PC.
  • AOpen HX08 ATX Case
  • AOpen AX59 Pro motherboard, upgraded to BIOS version 2.36
  • AMD K6-2@300Mhz
  • 256 megs of CAS 2 SDRAM
  • 64 gigs of storage provided by IDE to SD adapter
  • Diamond Speedstar A55 (S3Trio3D/2X), for DOS compatibility (replaced the Matrox MGA100 that was there originally)
  • Diamond 3D Blaster II Voodoo 2, 12 Megs
  • Hauppauge TV tuner PCI
  • DEC 21140 10/100 PCI network card
  • Orpheus sound card with PC-MIDI and Dreamblaster X2 (Buran + PCL preset) (replaced the SB16 Pro that was there)
  • Philips 2x CD-burner and Creative 24x CD-ROM
Had a lot of fun getting this operational again , thought I'd share some pics.
Sigurbjörn
    1.97 MiB
    1.48 MiB
    1.63 MiB
Reply 1887 of 2713, by bjwil1991
Photos of my Compaq Portable 1 system (the keyboard needs a retr0brite before I show photos since my OCD is in Overdrive).
http://imgur.com/a/SpIEDMc
Reply 1888 of 2713, by gerry
sigurbjornl wrote on 2021-03-16, 18:03:
This is one of my two retro rigs and the one I just finished […]
  • AMD K6-2@300Mhz
Sigurbjörn
that's one huge tower! Nice set up
Reply 1889 of 2713, by PD2JK
Oh yes, HX08. Built like a tank.
I have a few smaller HX45 cases. They don't get more robust than that.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 1890 of 2713, by afgncaap
Just for fun, i am setting up a superfast win98 system.
It's a socket 754 Athlon 64 3000 with 512 Mb ram.
I also have a 3400, so maybe i will swap it out.
the videocard is a Ati 9600 and the soundcard a Soundblaster live.
The motherboard is a Gigabyte GA-K8VM800M, it has Agp and all the win98 drivers are available on the website.
The cpu fan connector is not temperature controlled, so i used a resistor to slow down the fan, it's now barely audible, but still cools well.
I tried using the onboard sata ports with a 60 Gig ssd, but it wasn't recognized, seems like the Sata ports only understand sata 1.
i tried using a Ide to sata adapter, which worked at first, but after a few days the ssd suddenly got corrupted, lots of file errors, Windows wouldn't start anymore.
Now i reinstalled on a ide drive.
For now it's sitting on my test bench until i find a case to build it in.
133.49 KiB
    156.23 KiB
Reply 1891 of 2713, by chrismeyer6
That's going to make a super fast 98 machine. For the CPU fan you can use speedfan to monitor your temps and adjust fan speeds. You don't need a 4 pin pwm fan to control fan speeds.
Reply 1892 of 2713, by afgncaap
chrismeyer6 wrote on 2021-04-09, 12:17:
I tried speedfan, i can reed out the rpm and temps, but can't control the rpm. Doesn't mater, it works fine now.
Reply 1893 of 2713, by MadYoshi
- 2x Pentium III-S Tualatin 1,40 GHz, 133 MHz FSB, 512 KB Cache, inkl. Adapter aus Südkorea
- 2x Cooler Master HHC-L61 mit Lüfter 60x60x25 ~3000 RPM
- ASUS CUV266-DLS Rev. 1.03 mit Bios Rev.001 inkl. Tualatin Microcode
- 2048 MB, 4x NANYA 512 MB, DDR-400MHz-CL3 @ DDR-266MHz-CL2
- ASUS ATI Radeon X850XT PE AGP
- SCSI HDD, Fujitsu Enterprise MAT3073NP, Ultra320 @ Ultra160, 68 PIN
- SCSI ODD, NEC CD-3010A, 50 PIN Adapter auf 68 PIN
- FDD, MITSUMI D353
- Creative Sound Blaster PCI128 CT4810, PCI Karte
- USB2.0 VIA VT6212L, PCI Karte
- Ethernet Intel 82559 10/100 MBit, onBoard
- SCSI Controller Adaptec 7899 Ultra 160 36-bit, onBoard
- MAXDATA Favorit 1000I Case
214.75 KiB
258.76 KiB
464.83 KiB
Reply 1895 of 2713, by chrismeyer6
MadYoshi wrote on 2021-04-11, 21:59:
- 2x Pentium III-S Tualatin 1,40 GHz, 133 MHz FSB, 512 KB Cache, inkl. Adapter aus Südkorea - 2x Cooler Master HHC-L61 mit Lüfte […]
- FDD, MITSUMI D353
That is an absolutely beautiful system you built. It's super clean and the wiring looks great. I bet that thing is a monster power house with games. I also really like the looks of that case. Seriously great job. And welcome to Vogons it's a great community here.
Reply 1896 of 2713, by devius
kolderman wrote on 2021-04-11, 22:51:
Nice but
Exactly 😆 Everything is super over the top, except the sound card. What's the story behind that?
Reply 1897 of 2713, by PD2JK
I sold a few Maxdata systems 'back in the day'. German brand right? 😀
Reply 1898 of 2713, by MadYoshi
devius wrote on 2021-04-12, 18:00:
Nice but
I'm more of a fan of the Pentium III platform than of sound cards. I know the Sound Blaster PCI128 isn't the best, but I just had it there. If the board had sound on board, I would even have left it at that.
I am always open to suggestions with what I could replace the SB PCI128.
Reply 1899 of 2713, by PARKE
MadYoshi wrote on 2021-04-15, 18:51:
Maybe an Audigy 2 Zs with (black) I/O frontpanel ?
http://ixbtlabs.com/news.html?00/14/19
