First post, by Zaphod Beeblebrox
Hi, well, actually I didn't have any critical problem with it, the game runs off the bat with the default settings, I just wanted to know if there is a way in dgvoodoo to force the aspect ratio to 4:3 and use my native lcd resolution (which is 16:9) so the game won't stretch out.
I know there is a keep aspect ratio option on dgvoodoo (on the first tab under Miscellaneous), but it appears "grayed out" so I can't select it. Is there a way to enable those settings? thanks.
    61.31 KiB
    dgvd settings
Reply 1 of 4, by Davros
you mean force the aspect ratio to 4:3 instead of my native lcd resolution (which is 16:9)
Reply 2 of 4, by Zaphod Beeblebrox
Yeah, well, I mean, use my native 1600x900 resolution, but with "black bars" so the aspect ratio will be 4:3 as the original game resolution.
The option is there, "Preserve aspect ratio", but I cannot use it. I remember using it in the past but I don't remember how 🙁
"Passion, in its essence, means to suffer for what you love."
Reply 4 of 4, by Zaphod Beeblebrox
Yeah.
Ended up using nglide, apparently it only stretches the sprites but the 3D models remain at the original ratio it seems.
Thanks anyway!
