First post, by Sean-Der
Hello I have a
OPTi 82C924 Analog Devices AD1845JP
in a DOS computer that I would love to get up and running to play some Doom and Heretic, but the problem is I am COMPLETELY stuck I can not get any Windows 95 drivers for it and don't even know where to start as far as DOS support. If anyone has any advice it would be much appreciated! Thank you for your time
Reply 1 of 4, by retro games 100
I did a search on DriverGuide.com for Opti 82C924, and quite a few results appeared. Might be worth a go?
Reply 2 of 4, by Jorpho
Sean-Der wrote:
Doom and Heretic
May I suggest looking up some source ports? There's really no need to go back to DOS for Doom and Heretic. (In particular, Chocolate Doom aims to be practically identical to the original DOS Doom.)
Reply 3 of 4, by Sean-Der
Sadly have gotten nothing to work. I have been playing sourceports and DOSBox for the longest time, but hopefully now I can branch out and try some older games even! My catalogue of games is very limited sadly
Reply 4 of 4, by Jorpho
What did you try and what happened when you try it?
So... you have something that doesn't work in DOSBox?
