First post, by SlrG
I'm using dosbox version 0.74 on vista. I have an old typing software/game to learn the 10-finger typing system. If i run it within vista I'm not able to switch to fullscreen anymore, which was possible with XP. So I thought I give it a go under dosbox.
Overall it runs fine and I'm able to switch to fullscreen. Great! ๐ But there is one major glitch within dosbox. When one starts typing, the programm normally starts a counter from 00:00:00 which clocks the time it takes to complete the lesson. This value is used to calculate how many characters per minute are written.
If run in dosbox the counter starts with the current pc time, e.g. 16:33:12, which makes the calculated typing rate abysmal. ๐ข
Has anybody of you an idea where the problem is? Help is greatly appreciated. ๐
