CyanogenMod 7. is out!
First post, by DosFreak
http://downloadsquad.switched.com/2011/04/11/ … ndroid-devices/
It's official, folks! CyanogenMod 7 is now deemed stable enough to be called, well, stable. The ROM is available now for your fl […]
It's official, folks! CyanogenMod 7 is now deemed stable enough to be called, well, stable. The ROM is available now for your flashing pleasure on over 30 devices -- including some tablets. Don't worry, it doesn't disappoint; I've been using it through the development process for months and it's well worth the wait.
If you haven't been following the updates on its progress, here's a quick recap: It's based on Android 2.3.3 Gingerbread, it's got built-in root access with all the command-line goodies, Apps2SD capability (built-in), Incognito Mode for the Android Browser, built-in CPU frequency adjustment and scaling (including overclock and choice of governor), loads of UI improvements and interface tweaks, OpenVPN and SIP calling settings, USB/WiFi/Bluetooth tethering, FLAC support, an FM Radio player, and loads of other features and enhancements.
It's even got a one-click UI theme-switcher that T-Mobile helped develop (open-source, no less).
Even if you aren't into flashing custom ROMs on your expensive new smartphone, you have to admit that this release is a pretty great thing... After all, it means a fully-functional version of Android 2.3.3 is now running, with loads of bells and whistles, on about 30 devices whose manufacturers and carriers are simply too lazy to update.
Alright, enough jabbering. You can learn more about the ROM at CyanogenMod.com, or jump straight to the download mirror if you already know what you're doing!
I've been using the RC's for the past couple of months and they've been great!@
Make your games work offline
