First post, by bloodbat
For those willing to try the latest Munt emulator integrated in DosBox, I have made a build. It's compiled from the latest DosBox SVN at the time of this writing (3706) and the latest GIT for Munt-Reloaded as of 03/05/2011.
It's built using VC++ 2010, it also includes TraxxamigaEP's xbox360 d-pad patch.
Keep these in mind, if you download and use it, please:
-I have changed the interface to Sergm's one and the latest Munt from GIT as a static library, CPU usage is rather low now 😁
-It might or might not work for you, it's experimental and unstable built on experimental and unstable. Want stability? Use the official DosBox build.
-You may prefer the Munt sound of other builds.
-Some games might break, I know Innocent Until Caught does.
-It includes the Blood CD Audio fix from SVN, it also seems to help Carmageddon...
-Most important: don't bother the DosBox devs about this build.
Enjoy 😀
    dosbox_munt_.3706.7z
    912.24 KiB
    410 downloads
