USB mouse and DOS feasible?
First post, by F2bnp
Hello folks, I was using a PS/2 mouse and CuteMouse driver for DOS up until now. I got a new mouse yesterday, because quite frankly I was tired of the whole "clean your mouse once every two weeks" business. So I got a USB mouse and thought that by using a USB to PS/2 adapter it would work as a PS/2 mouse, but unfortunately it won't! I've tried enabling Legacy USB Support on the bios of my motherboard (Asus CUSL-2), but it isn't recognised in either Windows or DOS. As a USB mouse it works great under Windows, but I want to use it under DOS too.
Any ideas?
Reply 1 of 24, by 5u3
For an USB mouse to work with those ubiquitous little green adapters, it has to support both USB and PS/2 protocols. What model is your mouse?
Reply 2 of 24, by F2bnp
It's called Microsoft Optical Mouse 200.
I figured that something like that happened. 🙁
Reply 3 of 24, by 5u3
According to the data sheet (available here) this mouse only works on USB ports. I'm afraid you'll have to look for a model which specifically supports operation on PS/2 ports.
Reply 4 of 24, by Mau1wurf1977
Hmm that's a good topic!
I think we could really do with a list of USB mice, that are compatible on PS/2 ports!
Found this mouse from Lenovo:
Attaches to PS/2 port via USB-to-PS/2 Connector Cable
http://www-307.ibm.com/pc/support/site.wss/MIGR-43954.html
And this is a really really good gaming mouse from MS Also states PS/2:
Microsoft IntelliMouse Explorer 3.0
http://www.microsoft.com/hardware/en-us/p/int … r-3.0/B75-00113
Cheapy:
http://www.shintaro.com.au/products/06_keyboa … -SM02/index.php
Reply 5 of 24, by Tetrium
We could add to that list any USB mouse that is sold with a PS/2 adapter included in the package.
Though frankly, it seems easier to just go get a PS/2 mouse (though they are getting a bit less common).
My retro rigs (old topic)
Report spammers here!
Reply 8 of 24, by Svenne
I thought Cutemouse could scan USB ports?
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
Reply 9 of 24, by Tetrium
DosFreak wrote:
Wow....all these years and have never known that a USB mouse couldn't work with the adapter. Learn something new every day.
It's kinda the same for PS/2 mice when using a Serial adapter. If the mouse doesn't support the serial protocol internally, the adapter will not work.
Reply 10 of 24, by F2bnp
It will but only if it is recognised in DOS. By default DOS has no idea of what USB is 😁
Reply 11 of 24, by SquallStrife
From CuteMouse's homepage:
'Modern BIOSes often make USB mice visible through the PS/2 interface if you enable "legacy" support in BIOS setup.'
Reply 12 of 24, by schlang
I have a working UHCI driver for DOS, but it eats up > 100K of conventional memory so it's of no use to me...
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 13 of 24, by F2bnp
I managed to get it working, it seems like I hadn't enabled the USB Legacy option in DOS 😖
Reply 14 of 24, by emote
I use a Logitech MX518 which works fine in DOS through a PS/2 adapter.
Reply 16 of 24, by keropi
2 years ago I bought a dozen of Logitech SBF69 mice from eBay:
these are ps2-only optical mice, no longer in production... I had one since when they where first announced and is working excellent after all those years... so I thought a dozen will last me a lifetime 🤣 🤣 🤣
Reply 17 of 24, by Tetrium
I've got a small lot of these as well (may not be the exact same model though), these are excellent mice!!
Like em a lot!
Often these were rebranded as Dell, HP and Fujitsu also 😉
Edit:One problem some of these mice have, sometimes the mouse pointer teleports to some random location, but hey, I got them for around €2 each couple years back 😀
Reply 18 of 24, by megatron-uk
There are various versions of the Microsoft Optical/Intellimouse that are dual USB/PS2 compatible - I've got one here that states explicitly on the underside it supports both... the part number is X802652.
What I *would* like to find though, is another Logitech Trackman Wheel - the old white one with the red ball. Now that is a lovely thing... I have one on my main desktop, but I would love to have a second one on the KVM switch I run my SGI's, Amiga and retro PC through.
https://www.target-earth.net
Reply 19 of 24, by eL_PuSHeR
My last mouse (Logitech) was also working via a USB->PS2 adapter.
Now I have a PS2 only cheap Genius Netscroll one.
I am well aware PS2 ports are becoming a thing of the past for mainboards manufacturers. The trend is to add more USB ports. Thanks God newer bioses still have some rudimentary USB support for legacy Opertating Systems.
