First post, by pagefault
Was wondering if you could maybe implement more modems into DOSBox, and perhaps add a feature to map them all to one TCP port and it would automatically connect to the next free modem. The reason I am requesting this is because I would like to use dosbox to bring back some old BBS software and it would be pretty cool to be able to run a board online again.
Anyway if you don't feel like adding it, no problem. Just thought i'd suggest anyway.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
I have no idea to be honest. I believe the modem is a class so you can have as many instances as you like. There isn't an incoming trafic switcher though.
Water flows down the stream
