Reply 1 of 7, by Glidos
- l33t
You can download it and try it out. That's probably the best way to see.
Reply 2 of 7, by Carrera
Based on the number of posts I've seen I would so most of the older Tomb raider games and Cramageddon (spelling?) plus those mentioned on Paul's site.
A "supported games" list is on Snover's page but it is general and not GliDOS specific.
Reply 3 of 7, by Snover
- l33t++
You can sort by GliDOS support 😀
Yes, it’s my fault.
Reply 4 of 7, by VLC
- Newbie
wrote:You can sort by GliDOS support 😀
But what does that mean???
ALSO
ive got some old games like duke nukem 3d, doom 1, quake 1, an descent 1, + terminal velocity, which arent mentioned on the main glidos site, but....being that coding is sometimes similar, could glidos improve other unlisted games??
Reply 5 of 7, by Carrera
Go here:
http://zetafleet.com/dev/oli/compat.php
and one of the sort criteria is GliDOS.
Reply 6 of 7, by Glidos
- l33t
There's a Glide/Windows version of Descent 1 which you can run using just OpenGLide, but you are better off using D1X.
None of the others are Glide/DOS either, and each has source ports. See jdoom and glquake
Reply 7 of 7, by VLC
- Newbie
wrote:None of the others are Glide/DOS either, and each has source ports. See jdoom and glquake
Thanx for the 2 last posts but, as i'm new to this arena, ive some more queries....
1. do i assume that the list i got to 2 posts above, i consult to see what games can be viewed better, an is that the best/fullest/most update listing?
2. what is jdoom an glquake?
3. how can i check if my pc has the h/w to utilise all this new tech stuff i'm learning about off this nice forum here 😀
4. what are 'source ports'?
5. wheres the best place to download the fancy s/w that helps enhance old games?
sorry to ask but this is all new to me 🙁
