First post, by ratfink
Installed 98SE on my industrial motherboard today, seemed to go without a hitch until I got to the sound card.
System specs:
P4 2.8
Phoenix ATX-G AGP/PCI/ISA motherboard
CD ROM - 10GM HD - no FDD
onboard NIC enabled and working in 98SE
onboard AC97 audio disabled
onboard USB disabled [all various parts of it]
PNY 128mb FX5200 AGP, nvidia drivers 71.xx
SB16 ISA card, seems to have no CT number, its got CT1741 and CT1745 chips
new psu
Bios settings:
serial and parallel ports disabled
reserved IRQ5, IRQ7, DMA 0 and 1, 64kb memory for ISA devices
[no idea if memory is relevant to sound cards 😜]
Moon ISA device enabled [allows ISA devices to work!]
There are clock settings for 8-bit and 16-bit ISA compared to PCI clock, these are set at 4 but varying them seems to have no impact
SB16 sound card drivers install, either from 98SE CD or some sb16 drivers I have used previously in 98. Device manager shows no conflicts, device is working properly. Multimedia has SB16 selected for recording and playback [and MIDI fwiw]. Headphones plugged into correct jack and during testing I am varying the volume control on the back of the sound card.
Problem: When I call up Sounds control panel to test the sound card, when I play a sound there is just a louder or higher pitched hiss through my headphones. The volume panel indicates the sound plays continually so I have to click on the square to stop it playing etc. Sometimes - I am not sure exactly when this starts to happen as it can be immediately I try to play any sound - I get a message along the lines "Windows cannot play file xxxxxx, your sound card is/maybe in use".
Any ideas? Googling has thrown up issues with wrong devices selected for playback [its not that] or reinstalling drivers [I've done that].
