FMV pack does not work! Tomb Raider + Unfinished Business on Windows 7 64 bit
First post, by Ryu_Battousai
Hi!
Ich use Windows 7 Ultimate 64 bit and tried to get the German version of Tomb Raider 1 + Addon running. I proceeded as follows:
01. I removed all removable mediums safely via Windows and took them off.
02. I filled CD drive D: with the Tomb Raider CD
03. I filled my virtual CD drive G: with an ISO (Star Wars - Dark Forces)
04. I installed the preconfigured game to C:\TOMBRAID (via "TrAndUbForGlidos.exe")
05. I installed Glidos 1.49 (C:\Eigene Dateien\Spiele\Emulatoren\Glidos)
06. I installed "DOSBoxForGlidos_1_1.exe" (C:\Eigene Dateien\Spiele\Emulatoren\Glidos)
07. I installed the audio pack "TombRaiderAudio_v1_6_DE.exe" (C:\Eigene Dateien\Spiele\Emulatoren\Glidos\Audio)
08. I installed the FMV Pack "TombRaiderFMV_v1_2.exe" (C:\Eigene Dateien\Spiele\Emulatoren\Glidos\FMV)
09. I opened "Glidos.exe"
10. I chose "Adjust..."
11. "DOS" --> "Dos Emulation" --> "DOSBox" activated
12. "Enable Glidos's VESA emulation" activated (it already was by default)
13. "Audio & Movies" --> "Use Audio Pack" activated --> "Use FMV Pack" activated
14. Display --> "Full Screen" activated
15. Select: "Tomb Raider" --> "Start game"
Overview INI:
Executable: C:\Tombraid\Tomb.exe
ExeSizes: 873739
CDCheckFile: data\Level10c.phd
Driver: Direct3D
DosGraphics: Yes
VESASupport: Yes
ControlJudderFix: 1
Resolution: 3
FullScreen: Yes
TrShadowHack: Yes
RedbookEmulation: MP3
FMVPack: Yes
DosEmulation: DOSBox
My problem:
FMV videos are skipped! There's no Eidos logo, no intro before the start menu and no intro between start menu and the first level. I directly go to the menu and then straight to the game. If i deactivate the FMV pack all videos load smoothly.
General problem:
I had a look at the Avi files: They all are in English language without a second dubline. Do you have a German version of the FMV pack? In theory I could dub them with German language, if I somehow manage to achieve the dublines.
If you can instruct me how you extracted the FMV of the playstation game, I could even get the complete FMV videos of the German version and provide them to you.
My questions summarised:
1.) How about my settings in Glidos.ini? Are they in need of improvement?
2.) The only additional setting that I have activated is "TrShadowHack: Yes", do you recommend any further fix, hack or option that is available for optimum gameplay?
3.) Does a German FMV pack exist?
4.) If not: Can you help me to get videos in German language by myself (I could dub them or I could extract them from the German playstation game)
5.) Why does the FMV pack not work for me?
I would be grateful for any help. Thanks in advance!
Reply 1 of 48, by Glidos
Hmmm. You are the second person to report a problem, both from Germany, although I can't think why there would be a connection.
Can you play the movies in WMP? It is possible that you have a codec missing because of perhaps not being on the latest version of WMP. But if the movies play in WMP, then they should play through Glidos.
It would be great if you could get hold of a German Playstation version of TR and pull the fmvs off. You should be able to just open the FMV folder on the disc and drag out the files. I can then convert them.
Reply 2 of 48, by Ryu_Battousai
Yes, I already talked to Volker from laraunlimited.net. He told me that he has the same problem (he tried it with Win XP SP3 and Win 7 Professionell 64bit - both methods had the same issue).
I will have a look at my Windows Media Player this evening. But as I have installed the K-Lite Codec pack, I can't believe it's a codec problem...
Can you help me about my first two questions?
Okay, I will upload the German fmv files as soon as I can!
Reply 4 of 48, by Ryu_Battousai
Hi!
So, here's the news: I opened the Avi files via WMP and had no problem. No codec was missing.
However, I uninstalled K-Lite to see if something changes, but I was getting the same result afterwards.
Here's the log of Glidos (I don't know if it helps you):
Starting Glide Server v1.49 (c) Paul Gardiner 2001-2008 VESA mode 0x101 VESA mode 0x101 Open core.avi Open core.avi Play FMV Win […]
VESA mode 0x101
VESA mode 0x101
Open core.avi
Open core.avi
Play FMV
WinClose
VESA mode 0x110
VESA cmd 4F07, 0, 0, 0
Open escape.avi
Open escape.avi
Play FMV
WinClose
VESA mode 0x110
Open cafe.avi
Open cafe.avi
Play FMV
WinClose
VESA mode 0x110
VESA mode 0x101
Resolution = 640x480
Refresh rate = 60Hz
Color format = ARGB
Number of color buffers = 2
Number of aux buffers = 1
Refresh rate = 60Hz
Color format = ARGB
Refresh rate = 60Hz
Color format = ARGB
Refresh rate = 60Hz
Color format = ARGB
Refresh rate = 60Hz
Color format = ARGB
GlideShutdown
And last but not least:
Here you go, the unconverted German fmv files:
http://rapidshare.com/files/3401746684/FMV.rar
Hope I was helpful.
Reply 5 of 48, by Glidos
Thanks for the FMVs.
Can you try out the attached app to see if it will play the movies from the English FMV pack?
    Movie.exe
    140 KiB
    728 downloads
    Glidos' internal movie player in standalone form.
Reply 6 of 48, by Ryu_Battousai
Thank you! I tried... but unfortunately I failed just by opening the application!
This is what I got by running the app:
http://bayimg.com/BaIOeAaDe
(I downloaded an English language pack for my Windows 7 to make it more understandable for you)
Just for fun I also tried it with my Windows 98 Virtual Machine:
http://bayimg.com/baioGaaDe
(It says that a DLL file is missing)
Well, then I followed the advice of the error message:
http://bayimg.com/baiOIaAdE
...and received the MySxSTrace.txt file which you can find in the attachments. I hope it's useful for you.
(btw: Googling made me believe that all I have to do is installing "Microsoft Visual C++ 2005 SP1 Redistributable Package (x64)" and "Microsoft Visual C++ 2008 SP1 Redistributable Package (x64)". Unfortunately it didn't help.)
Thank you again for helping me! Maybe you can make out the error by reading the enclosed textfile.
    MySxSTrace.txt
    28.53 KiB
    395 downloads
Reply 7 of 48, by Glidos
Oops! Sorry. I sent you the debug version. No, you wouldn't have the dlls needed for that. This version should be better.
    Movie.exe
    52 KiB
    700 downloads
    Release version
Reply 12 of 48, by Glidos
That's result we want. So at least we now know that the problem is with playback of the movie, and not the monitoring of the game and triggering of playback.
Here's another version that may give more information concerning why playback failed.
    Movie.exe
    316 KiB
    695 downloads
    Player with better error reporting
Reply 14 of 48, by Glidos
Hmmm. Strange. That error says the format isn't supported, but I'm using DirectShow which is the same method as WMP. I am supporting two different methods, one that falls back to another if not supported. Here's a version of the player that goes directly for the fallback.
    Movie.exe
    316 KiB
    716 downloads
    Movie Player forcing use of VMR9
Reply 15 of 48, by Agent of the BSoD
Hi! I've got the same problem with the FMV's on my Windows 7 32bit system. My properties for it are the same as on the first post actually, and my issues are the same as Ryu_Battousai is having. Using DOSBox on Direct3D and VESA emulation. I tried switching the properties around to see if it would magically work, and nope. Didn't think it would anyway.
I also tried out the applications you've linked. The first two failed to open the file, and the second two both reported the same error code identical to the one Ryu_Battousai gave. It seems that both of us have the same problems. (also, there is one movie in the FMV's that's missing that's called ESCAPE, one of the startup FMV's)
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 16 of 48, by Glidos
That's bad news that the thrid version gives the same error. And do you also find that the movies play in Windows Media Player?
None of the Glidos settings will have any affect on this. It is some sort of difference in our DirectShow systems. I have them working fine on both Windows 7 64bit and on Windows XP 32bit, but they aren't completely clean installations. Possibly other DirectShow filters/codecs have been added as parts of other programs.
Reply 18 of 48, by Agent of the BSoD
Yeah, they play fine in my media player. (Windows Media Player) When I play the game through DOSBox, the FMV's don't appear, but try to. I get a blank white screen that stays for a few split seconds, and closes, for each FMV.
Reply 19 of 48, by Ryu_Battousai
Hi, so now we are three people having the same error (I counted Volker from laraunlimited.net).
I gave your last movie player a try too. I receive the same error as before - the format is not supported.
Uhm, what about the escape.avi? I didn't quite understand what you mean by "intensional"... Why is it missing?
