Aliens vs. Predator Gold
Getting old Windows games working.
Postby SKARDAVNELNATE » 2011-5-26 @ 19:30
I can't seem to get this game running properly on any of my systems.
I've installed AVP in Windows XP. At first the display was garbled and everything had trails reaching to the top left corner. I found a source code update here but it still isn't working right. First the level descriptions overlap with the difficulty menu, or wind up even lower on the screen so it disappears off the bottom. Second, I noticed during the Marine missions that the briefings which appear on monitors aren't playing leaving just the text from them. No animation or voice.
Next, I tried AVP in VPC 2007 running Windows 98. Apparently the mission loading screen causes it to crashes to desktop. This is after the intro movie. I disable intros in options and it still crashes after the difficulty is selected. I tried different resolutions and color settings with the same result
I then tried AVP in a Windows 98 system. At first I didn't get any display at all and after pressing enter a few times it returned to the desktop. I tried different resolutions and color settings which allowed me to see the opening and menus. Sometimes I could load the missions, others it would crash to desktop. This appears to be random as no combination of settings has worked consistently.
I also tried the source code update but it requires a newer version of Windows than 98. I thought about using the version of Direct X on the disc but it won't let me install that one since the version already installed is newer. Any other ideas?
User avatar
SKARDAVNELNATE
Re: Aliens vs. Predator Gold
Postby swaaye » 2011-5-26 @ 20:20
Yeah I have that Steam version. They updated the engine to support D3D9 and converted the CDA to MP3s or something similar so you get music without a CD. Works very well. It's more than just a simple repackaging so I'd say it's definitely worth $5.
swaaye
Moderator
Postby SKARDAVNELNATE » 2011-5-26 @ 20:57
Is there a patch to get the copy I already have working?
User avatar
SKARDAVNELNATE
Postby leileilol » 2011-5-26 @ 22:11
I remember running plain AVP Gold, AVP and even the early AVP demos just fine on XP. Radeon HD though...
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
DOSBox is not for running Windows 9x
SGL != Glide
User avatar
leileilol
Postby akula65 » 2011-5-27 @ 03:20
Check out this thread (and other threads in the Tech Support Forum) at PlanetAvP:
http://forumplanet.gamespy.com/tech_sup ... 64/p1/?140
User avatar
akula65
Postby Davros » 2011-5-27 @ 05:10
the probelms with avp were fixed years ago the light trial problem shouldnt exist any more (even without a fixed exe)
User avatar
Davros
Postby Tetrium » 2011-5-27 @ 07:19
Damn...brings back memories...though I played AVP2, it ROCKED!
I also have the AVP Gold laying around somewhere, but I think it's still wrapped in it's plastic like half of my games lol
User avatar
Tetrium
Postby SKARDAVNELNATE » 2011-5-27 @ 20:32
Davros wrote:the probelms with avp were fixed years ago the light trial problem shouldnt exist any more (even without a fixed exe)
In the thread akula65 linked to, it says to use driver 163.75 to fix that. The current driver is 270.61 so it would seem the trailing has been broken again.
User avatar
SKARDAVNELNATE
Postby Davros » 2011-5-29 @ 09:32
yep i just ran avp (ati 6950) and it didnt work
so i used the patch AvPx.zip and it works fine now (remember to run avpx.exe not avp.exe)
User avatar
Davros
Postby SKARDAVNELNATE » 2011-5-29 @ 11:28
Did you look for the text position and Marine video briefings? AvPx.exe makes the levels playable but there are still some features that need work.
User avatar
SKARDAVNELNATE
Postby Davros » 2011-6-01 @ 21:03
no just fired it up and had a quick look
User avatar
Davros
Postby Rekrul » 2011-6-01 @ 22:25
Tetrium wrote:Damn...brings back memories...though I played AVP2, it ROCKED!
AVP2 tied the levels together better, and it was nice to play all the stages of the alien, but I thought it felt a little too scripted. The Primal Hunt add-on is even worse. In the human campaign, you get ambushed every ten feet or so.
Tetrium wrote:I also have the AVP Gold laying around somewhere, but I think it's still wrapped in it's plastic like half of my games lol
The only thing I disliked about AVP Gold was the limited number of saves per level. I think on expert, you could only save three times. That's three times, not three save slots. And if you don't play all the levels on expert, you can't unlock all the bonus levels. I cheated and used a little hack that runs in the background and lets you save an unlimited number of times.
Also, I liked the alien models better in AVP Gold than in AVP2.
Rekrul
Postby leileilol » 2011-6-02 @ 01:58
Rekrul wrote:The only thing I disliked about AVP Gold was the limited number of saves per level.
Aw, that keeps the suspense up! Clearly, you haven't ever played the original unpatched notgold version which had no saves at all!
SGL != Glide
User avatar
leileilol
Postby Tetrium » 2011-6-02 @ 02:55
Rekrul wrote:Also, I liked the alien models better in AVP Gold than in AVP2.
Reminds me...I never liked the runner being a much lighter color then the drone, it made the runner more difficult to find a good hiding spot (man...online surviver mode...with the aliens as the survivers!! :D Hide and seek haha!!)
User avatar
Tetrium
Postby Rekrul » 2011-6-09 @ 08:03
No, and I wouldn't even attempt to!
Frankly, I hate games that don't allow in-level saving and I've passed up several games for that very reason. It's not that I consider myself a bad player, it's just that too many times you die for stupid reasons, like missing a jump, or not selecting the right weapon, or taking a wrong turn and getting trapped. When that happens, I don't consider it fun to have to replay the entire level over again.
Even with limited saves, unless you've already played and failed the level several times over, you don't have any idea where or when to save. I only have one save left, do I use it before opening this big door or do I chance it and risk losing all the progress of the last dozen rooms I've cleared? If I do save, how do I know that I don't still have half the level ahead of me?
A couple years ago, I played Spider-Man by Activision (which is buggy as hell on systems newer than it was designed for) and the game used checkpoints rather than allowing you to save. I had to replay some of the levels dozens of times. It didn't add anything to the game other than a lot of frustration at having to replay the same sections over and over and over and over...
Back to AVP Gold, I remember a section of corridor in one marine level where the lights were flickering on and off and a literally endless number of aliens drop out of holes in the ceiling until you reach the other end. I had to replay that section at least 30-40 times before I passed it. I came to hate that level.
Rekrul
Postby SKARDAVNELNATE » 2011-8-11 @ 15:06
Just discovered I have the same display problem with Dead Reckoning.
Fortunately this one works in Virtual PC 2007 running Windows 98.
Just discovered I have the same display problem with Forsaken.
Unfortunately in Virtual PC 2007 running Windows 98 I only see the left half of the screen. It seems okay on an actual 98 system though.
User avatar
SKARDAVNELNATE
Postby Rhindle » 2012-8-08 @ 04:37
Looks like the enhancement to AVP Gold linked by the OP has recently been updated. With it, I can now play the game perfectly on my laptop running Windows 7 64-bit.
Has anyone had any luck converting the audio tracks on their original disc into ogg files to get the game's music to play? The directions aren't very clear on how to do this and I'm having some trouble.
I have mine set up in a Music folder located in C:\Program Files (x86)\Fox\Aliens versus Predator. I then saved a text file (titled "ogg_tracks") inside the folder that reads exactly like this:
Track1.ogg
Track2.ogg
Track3.ogg
Track4.ogg
Track5.ogg
Track6.ogg
Track7.ogg
Track8.ogg
Track9.ogg
Track10.ogg
Track11.ogg
Track12.ogg
Track13.ogg
Track14.ogg
Track15.ogg
(Each audio track inside the folder is then named the same.)
The music still doesn't play however, so I'm wondering if I'm missing another step where I need to add some kind of command parameter into the game's config file? (I'm thinking of the one saved in C:\Users\[username\\Documents\My Games\Aliens versus Predator\AliensVsPredator.cfg. Or maybe I'm missing a key dll file or something?
Rhindle
Postby Davros » 2012-8-08 @ 13:11
SKARDAVNELNATE Forsaken is working fine for me in win7 x64
patch ver 1.01
User avatar
Davros
Postby sirlemonhead » 2012-8-12 @ 15:27
Rhindle wrote:Looks like the enhancement to AVP Gold linked by the OP has recently been updated. With it, I can now play the game perfectly on my laptop running Windows 7 64-bit.
Track1.ogg
Track2.ogg
Track3.ogg
Track4.ogg
Track5.ogg
Track6.ogg
Track7.ogg
Track8.ogg
Track9.ogg
Track10.ogg
Track11.ogg
Track12.ogg
Track13.ogg
Track14.ogg
Track15.ogg
Hi,
I might have broken the ogg vorbis playback code. I'll look into it asap and get a fix up on the site :)
User avatar
sirlemonhead
Next
Return to Windows
Who is online
Users browsing this forum: No registered users and 0 guests
