First post, by schlang
hi, could someone please upload the files CTSBPRO.SYS and CTMMSYS.SYS files for a Sound Blaster Pro to a file hoster (e.g. mediafire)?
Thanks in advance!
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 2 of 5, by schlang
Thanks, I already have checked the archive, but I could not find them in there as regular files (I can't perform the regular disk based installation).
Reply 3 of 5, by retro games 100
Here ya go!
Reply 4 of 5, by schlang
perfect, thank you very much 😀
but I still have a problem now:
Commander Keen 6 does not detect any sound blaster:
am I missing something? here are my autoexec.bat and config.sys:
@ECHO OFF
SET BLASTER=A220 I7 D1 T4
SET SOUND=A:\SB
SET MIDI=SYNTH:1 MAP:E MODE:0
SET DIRCMD=/O
SET PATH=A:\
LH A:\SB\SBFMDRV.COM
LH A:\SB\SBP-SET.EXE /R /X:0 /M:13 /VOC:13 /CD:13 /FM:13 /LINE:13
REM LH A:\CDROM\SHCDX33E.COM /D:MSCD001
LH A:\DOSKEY.COM
LH A:\KBD.COM
LH A:\MOUSE\CTMOUSE.EXE /R11
SWITCHES/F
DOS=HIGH,UMB
FILESHIGH=30
BUFFERSHIGH=30
FCBSHIGH=16,0
STACKSHIGH=9,256
LASTDRIVEHIGH=D
SHELL=A:\COMMAND.COM /E:768 /P
DEVICE=A:\HIMEM.SYS /TESTMEM:OFF
DEVICEHIGH=A:\EMM386.EXE RAM
REM COUNTRY=049,850,A:\COUNTRY.SYS
REM DEVICEHIGH=A:\CDROM\VIDE-CDD.SYS /D:MSCD001
DEVICEHIGH=A:\SB\CTSBPRO.SYS /UNIT=0 /BLASTER=A:220 I:7 D:1
DEVICEHIGH=A:\SB\CTMMSYS.SYS
Reply 5 of 5, by schlang
okay I removed the GUS MAX, now it works:
how can I disable SB emulation on the GUS MAX?
