First post, by cyberboyn
I read that some old software may not run on an NTFS drive. Does anyone know off-hand if Glidos Tomb Raider would have any problems on an XP install on an NTFS'ed drive? I have two PC's running XP on FAT32 and would ideally like them both on NTFS. Thanks.
Reply 1 of 2, by Snover
It has zero problems. In fact I'm still uncertain as to the vailidity of the claim that non-FAT formatting causing problems (I'm fairly certain it's Windows that's the problem not NTFS).
Yes, it’s my fault.
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
as far as i know there aren't any DOS_calls that operate directly on the FAT system.
Water flows down the stream
