Dominus wrote:Obviously the path to the images is different as well. Fix those and keep the case sensitiveness of linux in mind.
Not sure i get what you mean by this. I assume dosbox internal handling of files subdirs etc should be the same regardless if the binary is a windows or a linux one. Dosbox is dosbox , or...?
That is that root in DB is c:\ not whats outside the emulator. Then it whould be /media/win/whatever/dosbox/c:\games\blah\blah.cue, mixing windows filesystem and linux ( / and \ ....hmm) , meaning the whole (working) dosbox installment and all the bats whould need to be rewritten. If so it seems real silly 😜.
the imgmount is absolute path ie "c:\games\blah\blah.cue" . Orignially it was ".\blah.cue" but I changed it to absolute hoping it whould be foolproof that way.
The cue sheet are in order as else it could not have worked while running the same thing in windows dosbox.
If you feel I´m missing something please eleborate .
Thx
