First post, by Glitchologteam
Hello there, I would like to do a CD Image of PGA Tour Gold so I don't need to insert the CD each time. Ive used CloneCD to do a CCD, Bin/Cue and ISO Format. Ive test each one using a virtual drive K: of alchohol 120%.
Im mounting the virtual cdrom drive like a physicial one. Then, I mount the folder of PGAGold. When I write the executable (PGA486.com) It say
''UNABLE TO FIND CD???''
Golf Aborted
Even thought I tried a ISO, BIN/CUE Image or CDD.
I work with the physical CD Thought but like i said, I want to avoid using the CD each time I want to play.
Then I tried the following
imgmount c c:\pgagold\pgagold.iso -t iso
MSCDEX: Failure: Drive-letters of multiple CDRom-drives have to be continuous.
What I want : Being able to run PGA Tour Gold Edition with a Image
Thanks in advance for help
