First post, by iulianv
A few days ago I got this card: http://upload.wikimedia.org/wikipedia/commons … I601_Mozart.jpg
Then went looking for drivers (for DOS and Win3x) and found these: http://ftp.nchu.edu.tw/Hardware/multimedia/OAK/Mozart/
Then, having to choose between the first two files, I needed to find out what kind of OTI601 chip I have (B, E or F) - it seems to be F, according to this: http://www.plasma-online.de/index.html?conten … re/oak_oti.html
Then installed the drivers in the second file (it says "for OTI-601/E" at boot time though) and tested three games: Doom Shareware, Wolfenstein 3D and BOOM (with one of the WAD files on the Freedoom project site): http://www.teamtnt.com/boompubl/boom2.htm
The problem is that I cannot get the sound effects in BOOM to work (music is fine), no matter what sound driver I choose. Moreover, if I run BOOM first and then DOOM, I don't have sound effects in DOOM either. Wolf3D works just fine and it also "restores" sound effects in DOOM. I can also "restore" sound effects in DOOM if I run its setup first and change something minor (like the number of sounds/voices to be mixed simultaneously).
IIRC I found a comment somewhere here on vogons saying that the Mozart has serious compatibility issues and is to be avoided - is this my case too, or is there another, better, driver out there for me?
Reply 1 of 8, by elianda
I used this one and it worked. This also supports the OPL4 version of this card.
    MZRTINST.ZIP
    299.84 KiB
    714 downloads
    Mozart16 driver with OPL3/OPL4 support (OPL4 in Win3.x)
Reply 2 of 8, by iulianv
Found a potential "customer" for this card, but he wants all the sound cards he collects to work on WinXP - I found several references to a file named mozart16OTI601_NT.zip that's supposed to contain suitable drivers, but couldn't get the file itself - does anyone happen to have it?
Reply 3 of 8, by keropi
here, grab it 😊
    164.71 KiB
    424 downloads
Reply 4 of 8, by Aideka
I found the file online, but the readme says it is for Windows NT 3.51, nonetheless I will attach the file here.
EDIT: Damn, was too slow 😜
    164.71 KiB
    313 downloads
Reply 5 of 8, by iulianv
Thanks a lot for the fast answers - except for the User's Manual in PDF format the archive seems to contain the exact same files as some ntmozart.zip file I already had. Well, tomorrow I'll find out how useful these are for WinXP...
Reply 6 of 8, by soupapes
I have this sound card, I tried to install it in Windows98SE machine but it is not detected by windows.
- IBM Aptiva 2176/P166/Matrox Millenium 4Mb/Voodoo1 4Mb/48Mb/8Gb+8Gb SD-IDE/SB16/Win98SE
- 486 DX2 66/CL-GD5424/32mb/HD 600mb/Mozart601/Dos6.22+Win3.11
- P166MMX/S3VirgeDx/96Mb/8Gb SD-IDE/SB16/Win98SE
- P4 3GHz/FX5700/2Gb/HD 80Gb+160Gb/Win XP
Reply 7 of 8, by elianda
I guess that is to be expected as it is not a PnP card.
Youtube Channel
Reply 8 of 8, by rkurbatov
Just got this card as something unusual for my 1995 build
I have strong feeling that OPL4 daughterboard is just a waveblaster connector split on two. Need to check.
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
