Internet Explorer with DOSBOX on S60?
First post, by erdemöztürk
I have run Windows98 on my Nokia C5-03 with S60 DOSBOX, but it was so slow that we can't run any software. I want to run IE on my C5-03. Could I run IE 5-6 with dosbox? I know IE doesn't a DOS app. but could we run it?
If I have mistakes in article, sorry for bad English. English isn't my main language. If not, please tell me 😁
please use a signature that matches the other signatures on the forum.
Reply 1 of 20, by Jorpho
That's because running Windows 98 in DOSBox is not supported and generally a terrible idea.
You can probably run the 16-bit version of IE 5 in Windows 3.1 in DOSBox. I cannot comprehend why you would want to do this.
Reply 2 of 20, by leileilol
Phones aren't even fast enough to handle an emulated x86 running Windows 9X running IE. You're better off not wasting your time for some impractical unsupported nostalgic novelty of browsing the web on your phone with desktop browsers
Reply 3 of 20, by erdemöztürk
Actually, I have Opera Mobile / Mini; UC Browser, BrowserNG (Phone's original browser) and Bolt Browser (HTML Support for S60). But I want to try a real desktop browser. Just nostalgie 😁 And I want to run IE without Windows, and it was really a terrible idea.
Whatever, I will ask one more thing: If dosbox can run every dos application; can I run freedos and then run dos2unix for get Linux on my phone?
Reply 4 of 20, by leileilol
Dosbox isn't supposed to run 'every dos application'
it's supposed to run games
games
Operating systems with the illusion of being functional is a side effect from booting images. DOSBox does not support using Windows 9x or Linux within the emulator, and you're fooling yourself if you think it does.
Reply 5 of 20, by erdemöztürk
OK, than I will ask you my last question:
I have seen Need for Speed (for dosbox) on Turkish forums, and it needs a virtual keyboard. In phone, I have got a virtual keyboard app. but it can't work on DOSBox. If DOSBox has a virtual keyboard (I have seen on videos, but i didnt find) where is it or how can I get it? If there's no virtual keyboard, I have to create a keymap. 😢
Reply 7 of 20, by erdemöztürk
Thanks 😀 Its working 🙄
Reply 9 of 20, by sliderider
DosFreak wrote:
Your sig is annoying. Get rid of it.
Or at least make it smaller.
Reply 10 of 20, by Jorpho
Isn't dos2unix just a converter for text files?
Reply 11 of 20, by VileR
Maybe the version for lamers. I have seen the real dos2unix on Turkish forums, it patches any known version of DOS and converts it to a fully-functional UNIX-based OS of your choice.
Confirmed to work on a real MS-DOS v3.10 5.25" floppy, patched to the latest Ubuntu release and running stable on original PC/AT (I have seen on videos, but i didnt find).
Reply 12 of 20, by ADDiCT
Suuuure. This magic tool probably also allows one to run Crysis on a mobile phone.
Reply 13 of 20, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
But he as SEEN it 😉
I have seen at least a Dos 6.22 converter for Windows. It's a mighty hack. You start dos and then run some setup.exe in a directory filled with files and then suddenly (after about 30-60 minutes) you have Windows 95 on that machine. MIRACLE!!!
I guess that dos2unix works the same way 😉
@mods, plese force change that signature... 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 14 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
Sig removed.
That is an awesome converter! Wannahave!
Water flows down the stream
Reply 15 of 20, by VileR
On a mobile phone? sure, if you wanna go the easy way, but where's the fun in that... I use it to run Crysis on Win98, within DOSbox, running on Linux, installed on my AT&T model 500 rotary-dial phone!
BRB though, gotta post a help request thread and ask how to enter raw x86 opcodes in binary using the "0"s and "1" on my dial... I mean, it's supported, right? 😉
Reply 16 of 20, by garrynichol
Hi Doer:
I have already written a whole system for doing anything outside of dosbox in XP including IE.
Wokrs perfectly every time except you need a fast CPU unlike most game doers that want slow CPU's.
Let me know and I can send the package to you unhindged and no strings attached
-Garry J. Nichol (NTP)
Reply 17 of 20, by Jorpho
Runs on a cellphone, too, I bet.
Reply 18 of 20, by garrynichol
One could use the same concept on a cell phone but I haven'y done that.
Reply 19 of 20, by Jorpho
Heck if I know what you've "written", but in case you somehow missed the thread title and Mr. Doer's first post, the cell phone was kind of the whole idea here.
