First post, by lucky7456969
- Oldbie
Hello,
After changing font with fontedit, it falls back to default when returning to the prompt (after a game)
Are there anyways to make it stay resident?
Thanks
Jack
Hello,
Thanks
Jack
I'm assuming you mean the .COM font loaders that Fontedit creates. They're not "resident" in the usual sense because they're loaded into EGA/VGA video memory rather than program RAM. So it depends on what real graphics hardware would do when you exit a game (that is, changing back to text mode).
now, I THINK that changing modes (on real EGA/VGA hardware) always reloads the default ROM font for the target mode. Maybe this behavior differed across manfuacturers / chipsets, but if I'm right, then fonts created with Fontedit shouldn't normally persist after exiting a game. Maybe there are actual TSRs that help with this.
The app would have to hook int10 (and probably seek to the last non-rom hook
as some tricky TSRs do) which this one may or may not do (/do correctly).
