First post, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Another test build. No awesome new features, but two large patches neverteless.
1. EGA/VGA Video BIOS ROM area is removed from the machines that don't have it, CGA/Hercules/Tandy/PCJr.
This was causing some detection issues. Things to test: software for all these machine types, with focus on the non-EGAVGA.
2. Paging patch (from MB6)
Performance and compatibility improvement for some software that uses paging. The _slow cpu types were renamed since they are not slow anymore. To be tested with protected mode games, though quite a few of them don't use paging.
1+1=10
Reply 1 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Patch files:
1+1=10
Reply 2 of 7, by danielc
Very interesting, mostly the paging one - thanks for the DIFF's. Paging patch will indeed work with cputype:auto (and still switch to dynamic if needed) yes? Also, I have no idea which games use paging... happen to know of a list? Or an easy way to find out i.e. certain binary pattern or a specific file (extender?) that might be included with games?
Regards,
CosmicDan
Reply 3 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Hmm for me the video BIOS patch is the more important one, as I have another one that builds on it, and I'd like to finish that before I start with the aspect correction xD
To find out wether a game uses paging you need to add logging, it can't really from extenders. An indication is however if it is mentioned somwhere that the game can use a swap file.
Using paging:
Descent
Descent 2
First Encounters
GTA
Quake
Starcraft 😉
TTD
Windows 3.11
Wing Commander Armada
Wing Commander Privateer
Wing Commander 3
Not using paging:
Cursader: No regret
Duke 3D
Hioctane
Micro Machines 2
MOO2
Radix
Terminal Velocity
Warcraft 1
1+1=10
Reply 4 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There's a problem with keyboardlayout.
1+1=10
Reply 5 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
We don't want to load a codepage on machines with fixed ROM fonts. I hope the rest of the keyboardlayout function is up to this change.
1+1=10
Reply 6 of 7, by wd
Rank DOSBox Author
DOSBox Author
Yes, should be ok that way.
Reply 7 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
keyboardlayout works, keyb still hangs.
1+1=10
