Munt WinMM
First post, by Timar
Hi,
since the driver version of the lastes munt build won't work with Windows x64, I tried to run the WinMM command-line application (mt32emu.exe). However, it terminated with "Missing or incorrect MT32_CONTROL.ROM". Of course I have put both ROM files in the exe's directory and they do work with DOSBox. Do I have to put them somewhere else, or is the application not compatible with Windows 7 x64 (the readme says it is...)
Thank you...
Reply 1 of 3, by Kaminari
C:\Windows\System32
C:\Windows\SysWOW64
Reply 2 of 3, by Timar
Kaminari Redux wrote:
C:\Windows\System32
C:\Windows\SysWOW64
I have a copy there too. Where does the exe get the path from? There's no ini file included in the zip archive, just the exe and a readme...
Reply 3 of 3, by Kaminari
The exe checks for those paths. Your ROMs might be invalid for Munt.
