Character set issue
First post, by ManicD
OK dosbox 0.74 in default configuration
I'm trying to run a VERY old application on DOSBox,
The problem that I'm coming across is the difference between these two char sets
http://www.irongeek.com/alt-numpad-ascii-key- … -and-chart.html
I need the OS to recognise ALT-255 and not ALT-0255 (see link for reference, compare the blue and green grids)
Is there any support for this, or do I need to be looking at a different emulator?
Reply 1 of 9, by wd
Rank DOSBox Author
DOSBox Author
Why does your "very old" application use windows encodings?
Reply 2 of 9, by ManicD
The app was written for dos3.3
It requires access to two folders "y" and "y[ALT255]"
Without this it does not work, i can get it running on win7 x86
I need dosbox to get it on win7 x64
Reply 3 of 9, by bloodbat
The issue derives from Unicode...
I wrote you a little program file that might or might not help you, it will create a y folder with a unicode nbsp character at the end wherever you run it, it needs .net framework 4 and the source is included so you can tinker with it and find a unicode character that works for you if mine doesn't. The source is for Visual C# 2010 (it will work on Express). Since I don't have the program, I can't test it; running it under Windows doesn't really look promising because of the above Unicode issues, though you can try and see if some character works.
You can also try alt-0160.
Reply 4 of 9, by ManicD
unfortunatly its not teh creation of the directory that i need, I need dosbox to be able to read teh file path correctly, if teh folder is called "y " and dos box is looking for "yÿ" its not going to work.
this is what seems to be occuring
Reply 5 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
hmm I just checked.
255 is an allowed character in dosbox.
So I guess your operating system is doing some translation on the name ?
Water flows down the stream
Reply 6 of 9, by ManicD
just a point if i do a command in dosbox
mkdir xALT255xALT0255x
the output i see is
x x x
but windows displays this as
xÿxÿx
somehow i think DOSbox is confused between char sets
i'm wondering if i copy the files to a hard drive image file, if i would be able to work better eliminating windows and solely using dosbox
but i'm yet to figure out how to create and mount a hard drive, anyone who could give me line by line instructions on how to create a 10MB HD would be good
Reply 8 of 9, by ManicD
ok apparently it works as Yÿ
i just forgot i was mounting my c:\awbd folder as c:
the program needs it to be c:\awbd
so i set teh mouth to mount c to c and bingo (i know this is dangerous, but i dont mind i can sort that later
the program now runs, now i just have to sort a few odd errors.....this never ends!!!!
