First post, by Famicom
Hi guys.
There's a couple of issues regarding Tomb Raider running with GliDOS and DosBox (v0.73 -a special version for GliDOS-). I've asked the creator of GliDOS but he says those problems are most probably related to DosBox. Here they go:
- The sound is still a bit delayed, like in this video I found:
http://www.youtube.com/watch?v=aPXVNkucusY
It's almost unnoticeable until Lara starts shooting the bats and then keeps her guns at 0:46. I've seen other videos where such sound lag doesn't exist, so I don't know what to think.
- I'm using a joypad mapped with Xpadder. Everytime I run the game, the menu's rolling like crazy until I press all directions on the D-pad. Even then, it still rolls aleatory sometimes, and even Lara moves towards any direction for a sec -usually forward- right after loading a savegame.
Any help would be great. Thank you 😉
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
0.73 is old so nobody will really care (of course you could at least check the configuration file comments, but that's another topic).
Reply 2 of 4, by Famicom
It's supposed to be some kind of "special" or "modified" version of DosBox to work with GliDOS. I don't know whether you're responsible for that one, or the GliDOS creator is. All I know is that he's provided with this "special" version so that Win 7 users can still play Tomb Raider through GliDOS. As far as I know, by installing it, a DOSBox folder is created within the GliDOS folder. There's no config file or comments whatsoever (I don't think I quite understand what you mean by "configuration file comments"). Oh yes, there's a readme file (with no extension), containing this:
"This is a copy of DOSBox updated to work with Glidos. The changes are to allow
access to Windows named pipes from DOS programs, and to allow DOSBox to receive
key-press Windows messages when not the active window.
You are free to change copy and redistribute this software according to the
rights specified in COPYING-DOSBOX and COPYING-SDL. For details of obtaining
the source see SOURCE."
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
I don't know who built that version but if GliDOS has it for download he should know, and also should know why it's 0.73 and not 0.74.
Reply 4 of 4, by Xelasarg
Use ykhwong's SVN build instead: http://ykhwong.x-y.net/xe/dosbox_data/143.
"What's a paladin?!"
