OS X 10.6.8 causes lag on launch
Discussion about old PC hardware.
Postby Kurt Lang » 2011-7-07 @ 15:06
Just a note that the latest update to OS X causes the Intel version of DosBox .74 to hang while launching for about 5 seconds. Snapped open almost instantly under 10.6.7 or earlier.
After the interface finally comes up, it does run normally. This is mostly a note to the development team if they didn't already know of the issue.
User avatar
Kurt Lang
Re: OS X 10.6.8 causes lag on launch
Postby collector » 2011-7-07 @ 17:42
If this is about DOSBox, ask in the DOSBox forum.
User avatar
collector
Postby Dominus » 2011-7-07 @ 19:09
Works fine for me
User avatar
Dominus
DOSBox Moderator
Postby Sune Salminen » 2011-7-09 @ 04:16
No problem here either, DOSBOX starts up instantly.
User avatar
Sune Salminen
Postby Kurt Lang » 2011-7-19 @ 20:58
Whoops! Sorry, collector. I just clicked on the only heading that said "Macintosh". Despite that, can't figure out why the lag for me. Making it start without a preference file so it has to create a new one doesn't change anything. Hmm.
User avatar
Kurt Lang
Postby Sune Salminen » 2011-7-21 @ 06:21
User avatar
Sune Salminen
Postby Kurt Lang » 2011-10-16 @ 17:36
Found it. Any version of OS X, 10.6.8 or later (including Lion) must be allowing DOSBox to poll hardware it couldn't see before. If I unplug all of the extra USB or FireWire devices from my Mac, DOSBox snaps open instantly. Plug them back in, and it stalls as if it's trying to get info on a device.
So no real problem, I just have to wait a bit for DOSBox to open after it gets done polling hardware. It's likely stalling on a scanner that's turned off, but I haven't bothered to narrow it down now that I know what the general issue is.
User avatar
Kurt Lang
Postby Sune Salminen » 2011-10-16 @ 19:40
I'm running 10.6.8, I have six USB devices plugged in, three of which use proprietary drivers, and DOSBox starts instantly.
Maybe there's a problem with the driver for one of your USB devices.
User avatar
Sune Salminen
Postby Kurt Lang » 2011-10-20 @ 20:34
Thanks, but the devices all work fine. There are three USB dongles attached for various programs. I would bet if I unplugged those, DOSBox would start right up.
User avatar
Kurt Lang
Return to General Old Hardware
Who is online
Users browsing this forum: No registered users and 8 guests
