First post, by dada
- Member
Hi there, I was wondering if you guys could help me with Ethernet on Windows 95. I have an Ethernet card installed, the drivers seem to be working, but I can't seem to be able to connect to the LAN. The cable is confirmed working in its current configuration.
Here's what winipcfg says:
Basically the cable is connected to an Airport Extreme which should simply give an IP address to anything connecting to it. It works with all other machines I've used. Maybe it uses some sort of newer protocol that the drivers do not support?
