First post, by snickers
So, i can get things like commander keen and cosmo working, but whenever i try and run Duke, the text in DOSBox either turns yellow, or it just keeps creating a new line???
Reply 1 of 4, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Change output=surface under DOSBox configuration to anything else: overlay, ddraw, opengl...
Mine is set for ddraw and I am running it under W7. Depending on your graphic card some settings might be better than others.
Reply 2 of 4, by snickers
ok, i just tried that and none of them will open the game?
with all except surface i press enter, and it looks like its going to start the game and then it just sits at the screen DOSBox on a blank line (ie, just the flashing cursor??)
Reply 3 of 4, by VileR
which Duke game is it, exactly?
the first first shareware one should be able to run with the exact same settings as Cosmo anyway... are you using a frontend / multiple configs?
Reply 4 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Do you start the right executable?
1+1=10
