First post, by lyndz
Hello
Is there anyway I can pause dosbox, or freeze the screen momenarily by pressing a certain key? My reason for asking is that Im trying to play a game but the text messages flick on and off the screen too quickly to read. I have tried to slow down dosbox, but this makes the game unplayable alltogether.
So I was wondering if it was possible to somehow freeze or pause dosbox each time a message comes up.
Any suggestions?
Thanks in advance!
Reply 1 of 12, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
You can use debug version of CVS, break into debugger by pressing - on numeric keyboard and then continue by pressing F5 in debugger.
As far as I know there is not any normal Pause key implemented. 🙁
Mirek
Reply 2 of 12, by robertmo
If it is not an adventure game and there is not much text you can always make screenshots by pressing Ctrl-F5 and switch Alt-Tab between dosbox and your picture viewer running in backbround.
Reply 5 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
there are 2 ways pause could be implemented:
1 implement the pause key so games can pause themself.
2. implement a pause key that halts dosbox itself. Like the debugger mode.
those are really different !
The second way will pause every game/application that exists.
the first way is the way dos paused games (actually the bios but okay)
and can be disabled by the game.
Water flows down the stream
Reply 7 of 12, by iampiti
The first way would be nice just because it's an actual feature of the real thing.
...but I like more the second one because no program can skip it 😁
If you're going to implement one do the total dosbox pause, please.
p.s: Nice avatar Qbix 😀
Iampiti
Reply 9 of 12, by robertmo
Just wanted to say that if you set in DosBoxCVS for example:
cycles=2500
cycleup=2499
cycledown=2500
so pressing ctrl-F11 will pause and ctrl-F12 will continue 😀
(well.. not exactly but should be enough)
Reply 10 of 12, by icemann
The problem with having a pause key in PC games, is that no matter which key you assign as the "pause dosbox key", there will be a kazzillion and one games which use that exact key for something. The num lock key is about the only one I can think of, that no game I`ve ever played has used, but I`ll bet theres a few that do.
Two stones, two crosses, the rest is just icing. - 7th Guest
Reply 12 of 12, by jal
Well, you could of course try something with the Windows-key or that other special Win-only key. Or, even better, make the key configurable so you can set whatever Pause-key you want.
JAL
