First post, by Hatta
I picked up a couple 12mb Voodoo 2s off of eBay for SLI. Threw them into the first handy machine, which happened to be a 266mhz PII (al440lx) motherboard. Now this thing is obviously CPU limited. In Glide games, I can change resolution from 640x480 to 1024x768 with no change in FPS.
My question is, is it worth building another box around these cards? It's plenty fast enough for early Glide games. Plays Descent without a hiccup. But it's kind of slow for other Glide games, such as Swat 3. What has me unsure, is that most of the later Glide games support OpenGL as well as Glide. Would it make sense to put the Voodoo 2 cards into a P3 that already has a GF2 which outclasses the V2
I have two other candidate machines for these cards. One is a dual P3 450 IBM intellistation M Pro. The other is an Athlon XP 1800 on a Via chipset. I hesitate to use the P3, since 9x isnt' going to see both CPUs. It's also a little cramped in there, and I worry about ventilation. I hesitate to use the Athlon, since I don't know how well 9x is going to cope with the Via stuff from circa 2003. There's also no ISA slot, which I'd like to have for a SoundBlaster.
Any thoughts? What's the sweet spot in terms of CPU for a V2 SLI rig? What games am I missing out on by not upgrading? Are there games that require a p3 and run best on a real Voodoo?
