MPC Battle Chess - No Music
First post, by giblet_squasher
Motherboard - Not sure but my computer is a eMachines T3256.
Processor - AMD Athlon XP 3200+
RAM - 512MB DDR (PC2700)
Sound Board - NVIDIA nForce 2
Operating System - Microsoft Windows XP Home Edition SP3 (My game will be running in Windows 3.1 inside of DOSBox)
Game - Battle Chess Enhanced (MPC Battle Chess)
Problem - Everything works perfectly, including some sound, except for music and combat sounds.
SOUND/AUDIO NOTE: Sound card used for casual sound effects, CD audio used for background music and combat sequence sounds.
Version - DOSBox 0.74
dosbox-0.74.conf -
# This is the configurationfile for DOSBox 0.74. (Please use the latest version of DOSBox)
# Lines starting with a # are commentlines and are ignored by DOSBox.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
# fulldouble: Use double buffering in fullscreen. It can reduce screen flickering, but it can also result in a slow DOSBox.
# fullresolution: What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# Using your monitor's native resolution with aspect=true might give the best results.
# If you end up with small window on a large screen, try an output different from surface.
# windowresolution: Scale the window to this size IF the output device supports hardware scaling.
# (output=surface does not!)
# output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb, ddraw.
# autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
# sensitivity: Mouse sensitivity.
# waitonerror: Wait before closing the console if dosbox has an error.
# priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
# pause is only valid for the second entry.
# Possible values: lowest, lower, normal, higher, highest, pause.
# mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the defaul value.
# usescancodes: Avoid usage of symkeys, might not work on all operating systems.
fullscreen=true
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
usescancodes=true
[dosbox]
# language: Select another language file.
# machine: The type of machine tries to emulate.
# Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
# captures: Directory where things like wave, midi, screenshot get captured.
# memsize: Amount of memory DOSBox has in megabytes.
# This value is best left at its default to avoid problems with some games,
# though few games might require a higher value.
# There is generally no speed advantage when raising this value.
language=
machine=svga_s3
captures=capture
memsize=16
[render]
# frameskip: How many frames DOSBox skips before drawing one.
# aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler: Scaler used to enlarge/enhance low resolution modes.
# If 'forced' is appended, then the scaler will be used even if the result might not be desired.
# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
frameskip=0
aspect=false
scaler=normal2x
…Show last 186 lines
[cpu]
# core: CPU Core used in emulation. auto will switch to dynamic if available and appropriate.
# Possible values: auto, dynamic, normal, simple.
# cputype: CPU Type used in emulation. auto is the fastest choice.
# Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.
# cycles: Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# Cycles can be set in 3 ways:
# 'auto' tries to guess what a game needs.
# It usually works, but can fail for certain games.
# 'fixed #number' will set a fixed amount of cycles. This is what you usually need if 'auto' fails.
# (Example: fixed 4000).
# 'max' will allocate as much cycles as your computer is able to handle.
# Possible values: auto, fixed, max.
# cycleup: Amount of cycles to decrease/increase with keycombo.(CTRL-F11/CTRL-F12)
# cycledown: Setting it lower than 100 will be a percentage.
core=auto
cputype=386
cycles=fixed 3500
cycleup=10
cycledown=20
[mixer]
# nosound: Enable silent mode, sound is still emulated though.
# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
# Possible values: 1024, 2048, 4096, 8192, 512, 256.
# prebuffer: How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=1024
prebuffer=20
[midi]
# mpu401: Type of MPU-401 to emulate.
# Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
# Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
# See the README/Manual for more details.
mpu401=none
mididevice=win32
midiconfig=
[sblaster]
# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
# sbbase: The IO address of the soundblaster.
# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
# irq: The IRQ number of the soundblaster.
# Possible values: 7, 5, 3, 9, 10, 11, 12.
# dma: The DMA number of the soundblaster.
# Possible values: 1, 5, 0, 3, 6, 7.
# hdma: The High DMA number of the soundblaster.
# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
# Possible values: auto, cms, opl2, dualopl2, opl3, none.
# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
# Possible values: default, compat, fast.
# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
sbtype=sb1
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=opl2
oplemu=default
oplrate=22050
[gus]
# gus: Enable the Gravis Ultrasound emulation.
# gusrate: Sample rate of Ultrasound emulation.
# gusbase: The IO base address of the Gravis Ultrasound.
# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
# gusirq: The IRQ number of the Gravis Ultrasound.
# Possible values: 5, 3, 7, 9, 10, 11, 12.
# gusdma: The DMA channel of the Gravis Ultrasound.
# Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
# pcrate: Sample rate of the PC-Speaker sound generation.
# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
# Possible values: auto, on, off.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks),
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# (Remember to reset dosbox's mapperfile if you saved it earlier)
# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
# autofire: continuously fires as long as you keep the button pressed.
# swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
# serial1: set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq (optional).
# for directserial: realport (required), rxdelay (optional).
# (realport:COM1 realport:ttyS0).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
# Possible values: dummy, disabled, modem, nullmodem, directserial.
# serial2: see serial1
# serial3: see serial1
# serial4: see serial1
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms: Enable XMS support.
# ems: Enable EMS support.
# umb: Enable UMB support.
# keyboardlayout: Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
# ipx: Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
mount c C:\DOS_C
mount d E:\ -t cdrom
c:
cd windows
I've already tried different sound settings in the .conf file. I've also already tried the different parameters suggested in the readme when mounting my cd-rom. I do have an audio cable between my cd-rom and my motherboard too. I'm at a loss. My nostalgia is being ruined. I'm devastated. Please help.
*edit* - I've installed all the relevant drivers that I can think of in Windows 3.1 (tried both soundblaster 1.0 and 1.5, installed cd audio etc...)
Reply 1 of 22, by Gamecollector
Check the "enable digital CD audio for this CD-ROM device" in the Xp Device Manager for all CD/DVD drives in your PC.
Reply 2 of 22, by giblet_squasher
I'm glad you brought this up because I forgot to mention I had unchecked that to force it to use the analog cable (at least I think that's the effect it would have). I rechecked it like you said and still nothing, but I did notice that when it's unchecked my mouse cursor lags in the game like it's trying to do something but failing. No lag at all when it is checked but still no music either way. Thanks.
Reply 3 of 22, by bloodbat
Any particular reason why you would want to force analog audio?
There was a DOS version of that game and, for me, that works right with music and such. Why not use that one?
First question: the audio works right from the CD if played say...in Winamp? (They're Redbook tracks).
Just for the sake of testing...try playing an audio CD within your Win 3.1 install in DosBox...
Here's a suggestion:
-Make an image of your disc (as .cue/.bin pair, an iso won't do) and mount that in DosBox to play.
Update: I just tried the Win version (it's in the same CD, after all) and it barfed an error about CD Audio and not being able to load the drivers for it. So, it's Windows' fault 😜
If you're hellbent on playing it under Windows (even the DOS menus are prettier) read this, particularly the first question: ftp://soporte.uson.mx/DRIVERS/AUDIO/mozart/AUDFAQ~1.HTM
As usual Google is your friend.
Reply 4 of 22, by giblet_squasher
I just figured games that old only used a CD-ROM audio cable. I checked it back though.
In winamp it just plays a garbled electronic noise.
Audio CDs actually play fine in Windows 3.1 except I still get an error and the CD won't stop playing until I exit DOSBox. Pressing stop in the media player prompts the error and it just keeps playing.
I installed the DOS version and still no music. I do want those pretty menus too. I'm baffled.
Reply 5 of 22, by robertmo
maybe check dosbox manual for different cdrom settings
Reply 6 of 22, by bloodbat
giblet_squasher wrote:
I just figured games that old only used a CD-ROM audio cable. I checked it back though. […]
About the cable: yes it is needed...if using real DOS...no need for it in DosBox (with a capable OS, as yours seems to be).
About the garbled electronic noise: try playing track 2 (or any from the remaining 20), track 1 is the data track and will, indeed, produce garbled noise. If any other media player, not DosBox refuses to play the CD (starting from track 2, not 1)...you may very well have a screwed CD, it's old, you know? 😜
Besides listening to robertmo's suggestion, I also advise, again, to make an image and mount that in DosBox using imgmount. (if your CD is not screwed, that is).
Reply 7 of 22, by giblet_squasher
I made a bin/cue image file from the disk and mounted it in DOSBox and still no music. Must be a bad disk. I'll just buy another one. :p
Reply 8 of 22, by bloodbat
Did you try the other audio tracks? Also, before wasting money, try it with the DOS version.
Reply 9 of 22, by giblet_squasher
It just shows up as 1 track in Winamp and in the media player in Windows 3.1.
Reply 10 of 22, by giblet_squasher
I tried it with the DOS version and now it has no sound at all.
Reply 11 of 22, by Xelasarg
Set irq=5 in dosbox.conf and run BC4000 setup to make sure the right sb card is set as music and sfx card.
"What's a paladin?!"
Reply 12 of 22, by bloodbat
Are the settings properly...err...set in the config program?
You need to select the right IRQ, address and DMAs, though I'm not sure if the default for Battle Chess MPC is 5 or 7 (not 4000, see the difference here: http://www.mobygames.com/game/battle-chess-4000 and here http://www.mobygames.com/game/battle-chess-mpc-version).
DosBox 0.74 defaults to IRQ 7, 220 as address, DMA 1, HDMA (16 bit DMA) 5 and Sound Blaster 16
Reply 13 of 22, by giblet_squasher
When sound was working in the DOS version, I was using Sound Blaster 1.0 with a IRQ of 7 and a DMA of 1. I have no idea what I did other than reinstall the game using my bin/cue image. After that, no sound at all. I've tried reinstalling it with Sound Blaster Pro and changing the cards and IRQ/DMA values in the .conf file but still nothing.
The only options for sound cards the CDCHESS installer program gives me are Sound Blaster, Sound Blaster Pro, and a couple of Pro Audio 16 choices.
Reply 14 of 22, by Gamecollector
DOS version is working perfectly for me with the DOSBox. Sbtype=sb16, irq=7, dma=1 in dosbox.conf. And "SBPro" when installing cdchess. CD mount string was "mount d k:\ -t cdrom".
It looks like I don't have [MCI]CD Audio driver in my WfW 3.11 in DOSBox. So - this is the cause for "no music" in MPCChess. When I find my WfW floppies - I check this again.
giblet_squasher - check the TOC of the CD - it must have 1 data track and 21 CDA tracks.
Reply 15 of 22, by Xelasarg
bloodbat wrote:
not 4000
Damn, you're right. Noone in this whole thread even mentioned BC4000. 😵
*Makes a mental note: read properly before posting crap!*
Reply 16 of 22, by giblet_squasher
My TOC file only shows one data track being the bin file. :( Are there any special options I can use when making my image so I can get the 21 CDA tracks to show up? Thanks.
Reply 17 of 22, by giblet_squasher
I tried the Sound Blaster settings too. Thanks all.
Reply 18 of 22, by bloodbat
My TOC file only shows one data track being the bin file. 🙁 Are there any special options I can use when making my image so I can get the 21 CDA tracks to show up? Thanks.
Maybe your CD doesn't have those audio tracks...hm hm...Otherwise...Make the image properly?
Reply 19 of 22, by robertmo
sorry but have you checked dosbox manual for different cdrom settings? they are designed specially and only for cd audio problems
