The attached .sdb makes Warlords III Darklords Rising playable on Windows 7 machines. Two things are fixed:
ForceDirectDrawEmulation - fixes color palette issues
EmulateGetDiskFreeSpace - prevents the game from complaining about disk space on startup
Simply unpack the archive and run wl3dr_compatibility.bat to install the fix. The batch file has to be run with administrative rights (right click, run as administrator)!
When playing Warlords 3, Darklord.exe should be called with the parameter /WINCURSOR
