First post, by Jolaes76
Has anyone ever succeeded in properly installing and getting SB16 emulation drivers work for an Audigy 2 ZS card in win98? I know it MUST be possible with some sort of tweaking or hacking, because one time I installed Audigy 2 ZS WDM drivers in win98, then used the driver utility to switch to ".vxd" drivers, then installed SB16 emulation drivers of an Audigy (1) card. I managed to set its resources in a way it did not conflict with anything in the system. Then started DOS games and before I was kicked back to desktop, I heard perfect music/ effects for a few seconds, whatever the given game started up with.
The SB16 emulation driver also exists on the install CD of the Audigy 2 ZS, but it never gets installed and manual install will not work (there is always a resource conflict with other devices)
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
