First post, by astroraptor
- Newbie
I'm running DOSBox on a new system without a modem, I don't plan on getting one either. I'm just wondering if there's a way to fool DOSBox into thinking it's dialing in to access the Internet.
Do you want to access the whole Internet, or just another computer connected to Internet? If it is the latter, you can use a virtual modem on both sides:
[Thread moved to DOSBox General Section]
Ignore my previous message. DosBox already supports internal modem emulation.
That it does. ATDT+IP Address will work in any standard terminal program.
DosBox Guide to Multiplayer Games
Mind you, if you're not trying to connect to someone else running DOSBox, and you're not just trying to do telnet – that is, if you're actually trying to run Internet applications – it gets more complicated.
wrote:I'm just wondering if there's a way to fool DOSBox into thinking it's dialing in to access the Internet.
why do you want to do that ?
Megabuild6 of Dosbox features NE2000 network card emulation through WinPCap. So you get a emulated network adapter that is physically your hosts network adapter.
This way you would get network directly without dial-in.
