Ring of Zilfin
First post, by AQ_5
I'm having problem in playing the game in my pc..
I already installed the DOSBox but when I the DOS screen shows up I have no idea what to do, I know that the game only works with DOS so the DOSBox is what I need, and I "mounted c:\" .
Can anyone guide me to work this problem out,
I would really appreciate it..
Reply 1 of 2, by robertmo
read the guides on forum
Reply 2 of 2, by Xelasarg
60 seconds guide to getting your game to run in DOSBox
For starters, your mount command is wrong, which you should have noticed if you'd taken a look at the DOS prompt after typing "mount C:\".
Hint: do NOT "mount c C:", you'll end up killing your hard drive.
"What's a paladin?!"
