First post, by bloodbat
Hello, I made a DosBox build that supports compressed CD audio tracks since it's a feature I missed in 0.74, I figure some folks will find it useful, so it's attached to this post; it also includes built in MT-32 emulator, and TraxxAmigaEP's patch for using an XBOX-360 controller's D-pad instead of the analog joystick.
Everything is built from the latest sources (stable ones for the libraries, the latest SVN for DosBox and the latest GIT for Munt) using VC++ 2010. Needless to say, it's for Win 32 only.
MP3 support is built in but it doesn't seem to work properly, so I recommend you use .ogg files.
As usual, please, don't bother the DosBox devs. if this build glitches or does not work as you intend it to (it works fine for me).
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
ogg should work in stock dosbox as well ?????
Or am I mistaken somehow ?
Water flows down the stream
Reply 2 of 2, by bloodbat
You're absolutely right...
So...
a) I dreamt I tested it and in my dream didn't work (has happened before)
or
b) I got mislead by reading something, probably in this forum while sleepless.
or
c) it no longer works in SVN, which is what I could have tested.
or
d) all of the above.
Oh well, I built it anyway, maybe someone will find it useful.
