First post, by Grumble
- Newbie
I am getting this error:
This error appears with the default values in the dosbox.conf. I have increased the value in the memsize= but the same error occurs.
How can I solve this issue?
http://forums.virtualbox.org/viewtopic.php?f=2&t=43393
According to that it could be a messed up HD.
I eventually managed to get it to install though with errors popping up at the end. I created another hard drive image with WinImage. Imdisk was a bit awkward. Bochs threw up the same error at the start as well. Now I have the problem of Win98 not fully loading past the log-in screen and I just got a Rundll32 Illegal Operation message while in safe mode.
Now works with 32 bit colour on a 640x480 resolution but explorer keeps crashing.
cputype=pentium_slow should help.
use the setup.exe option to ignore errors.
setup.exe /im
more options here:
http://www.theosfiles.com/os_windows/ospg_w98 … #setup_switches
ESS PCI DOS Drivers
_________________
