First post, by ProfessorProfessorson
- Member
Ok, so anyway some things have been changing with half my systems due to the yearly upgrade. I removed my systems from the rig specs thread post until I get time to list everything again, and after I do I will do threads for each rig and link to them on a post in that main one. So, for this thread:
My AMD 3DFX Voodoo 5 5500 rig. I came across this one case that was all beat up to hell and back, but I just knew I could make it shine again, and had some good ideas of what to stick inside. I gutted my 3DFX Banshee build so I could use the Athlon XP 2400+ and Asrock K7VT2 motherboard in this.
Took out the one 256 meg stick of ram I had in there and slapped in a matching pair of DDR 333mhz 256 meg sticks. Ditched the Ensoniq AudioPci in favor of a SB Live! Value card. Kept the 40gb harddrive and two CD/DVD drives. Did a fresh install of Windows ME. Ditched the Banshee in favor of a AGP Voodoo 5500. Added a SuperDisk drive.
Work on the case involved sanding the entire bottom and some internal areas that had rusted. After the sanding was done and rust murdered by slaving hands, the bottom of the case and some internal areas were painted blue. The internal paint job is so so, as my only real concern was the motherboard area where there was rust spots, so it looks frosted in spots on the hard drive bay area instead of fully painted.
The window had some scratches and scuffs. To make it visually more appealing I painted its heavily scratched side, maintaining just the right layer of paint so that a led fan could light up the plastic still, and installed it flipped around so the paint side was internal. In the dark up close in person you can see the side lit up, and see the outline/silhouette of everything inside the case about. Hard to explain, but like looking in a dark ocean with a light shining on a ship wreck or something, and the majority of scratches that were present are no longer visible due to being filled in by the paint.
The drive bay plastic pieces were removed, along with the front metal mesh grill things, and painted in a few coats of black, then clear coat to prevent chipping/scratches. 2 normal case fans and one Blue Led one were installed for intake and outtake. The entire white front of the case, and the top handle area were removed and washed via dishwasher to remove grime, etc. Power supply is a Dell ATX 250 watt (I love those things, they seem to never die, have not had one go out on me yet).
3D Mark 2000 and 2001 scores were achieved using one of the last official 3DFX drivers (geometry assist turned on), and normal official drivers for all else also. No overclocking or tweaks done yet.
3D Mark 2000:
TEMPLATE
Display:
Type:	Internal
Width:	1024
Height:	768
Depth:	16-Bit
Buffering:	Triple
Z-Buffering:	16-Bit
Refresh Rate:	VSync Off
Texture Format:	16-Bit
Options:
Continuous Benchmark:	No
Show Title Screens:	Yes
Benchmark Run Count:	1
Continuous Demo Mode:	No
Sounds Enabled:	Yes
CPU Optimization:	D3D Hardware T&L
RESULTS
Platform:	Internal
3DMark Result:	5705	3D marks
CPU Speed:	354	CPU 3D marks
Game 1 - Helicopter - Low Detail:	115.5	FPS
Game 1 - Helicopter - Medium Detail:	80.3	FPS
Game 1 - Helicopter - High Detail:	31.3	FPS
Game 2 - Adventure - Low Detail:	116.1	FPS
Game 2 - Adventure - Medium Detail:	81.8	FPS
Game 2 - Adventure - High Detail:	50.5	FPS
Fill Rate (Single-Texturing):	512.5	MTexels/s
Fill Rate (Multi-Texturing):	591.4	MTexels/s
High Polygon Count (1 Light):	6804	KTriangles/s
High Polygon Count (4 Lights):	6792	KTriangles/s
High Polygon Count (8 Lights):	6450	KTriangles/s
8MB Texture Rendering Speed:	326.5	FPS
16MB Texture Rendering Speed:	321.6	FPS
32MB Texture Rendering Speed:	229.7	FPS
64MB Texture Rendering Speed:	7.5	FPS
Bump Mapping (Emboss, 3-pass):	156.9	FPS
Bump Mapping (Emboss, 2-pass):	204.5	FPS
Bump Mapping (Emboss, 1-pass):	326.2	FPS
Bump Mapping (Environment):	Not supported	FPS
TEMPLATE
Display:
Type:	Internal
Width:	1024
Height:	768
Depth:	16-Bit
Buffering:	Triple
Z-Buffering:	16-Bit
Options:
Sounds Enabled:	Yes
CPU Optimization:	D3D Software T&L
RESULTS
Platform:	Internal
3DMark Result:	5451	3D marks
CPU Speed:	313	CPU 3D marks
Game 1 - Helicopter - Low Detail:	112.9	FPS
Game 1 - Helicopter - Medium Detail:	77.8	FPS
Game 1 - Helicopter - High Detail:	29.5	FPS
Game 2 - Adventure - Low Detail:	112.2	FPS
Game 2 - Adventure - Medium Detail:	76.7	FPS
Game 2 - Adventure - High Detail:	45.1	FPS
High Polygon Count (1 Light):	6759	KTriangles/s
High Polygon Count (4 Lights):	6019	KTriangles/s
High Polygon Count (8 Lights):	4736	KTriangles/s
8MB Texture Rendering Speed:	318.8	FPS
16MB Texture Rendering Speed:	316.0	FPS
32MB Texture Rendering Speed:	261.4	FPS
64MB Texture Rendering Speed:	180.0	FPS
Bump Mapping (Emboss, 1-pass):	326.3	FPS
3D Mark 2001:
DISPLAY
Platform	Voodoo5 5500 AGP
CPU Optimization	D3D Hardware T&L
Width	1024
Height	768
Depth	16 bit
Z-Buffering	16 bit
Texture Format	16 bit
Buffering	Double
Refresh Rate	60 Hz
FSAA Mode	None
OPTIONS
Show Title Screens	Yes
Continuous Benchmark	No
Benchmark Run Count	1
Demo Sounds Enabled	Yes
Continuous Demo	No
Game Sound Effects Enabled	Yes
Game Music Enabled	Yes
Game Detail Level	Low
RESULTS
3DMark Score	2686
Game 1 - Car Chase - Low Detail	45.3 fps
Game 1 - Car Chase - High Detail	18.6 fps
Game 2 - Dragothic - Low Detail	37.6 fps
Game 2 - Dragothic - High Detail	12.2 fps
Game 3 - Lobby - Low Detail	63.9 fps
Game 3 - Lobby - High Detail	30.2 fps
Game 4 - Nature	Not supported by hardware
Fill Rate (Single-Texturing)	453.0 MTexels/s
Fill Rate (Multi-Texturing)	587.5 MTexels/s
High Polygon Count (1 Light)	4.8 MTriangles/s
High Polygon Count (8 Lights)	2.8 MTriangles/s
Environment Bump Mapping	Not supported by hardware
DOT3 Bump Mapping	Not supported by hardware
Vertex Shader	19.8 fps
Pixel Shader	Not supported by hardware
Advanced Pixel Shader	Not supported by hardware
Point Sprites	1.2 MSprites/s
DISPLAY
Width	1024
Height	768
Depth	32 bit
Z-Buffering	24 bit
Texture Format	Compressed
Buffering	Double
Refresh Rate	60 Hz
FSAA Mode	None
OPTIONS
Continuous Demo	No
RESULTS
3DMark Score	2504
Game 1 - Car Chase - Low Detail	43.5 fps
Game 1 - Car Chase - High Detail	17.5 fps
Game 2 - Dragothic - Low Detail	36.4 fps
Game 3 - Lobby - Low Detail	55.7 fps
Game 3 - Lobby - High Detail	27.8 fps
Fill Rate (Single-Texturing)	315.5 MTexels/s
Fill Rate (Multi-Texturing)	570.9 MTexels/s
High Polygon Count (1 Light)	4.7 MTriangles/s
Vertex Shader	19.9 fps
DISPLAY
CPU Optimization	D3D Software T&L
Width	1024
Height	768
Depth	16 bit
Z-Buffering	16 bit
Buffering	Double
Refresh Rate	60 Hz
FSAA Mode	None
OPTIONS
Continuous Demo	No
RESULTS
3DMark Score	2765
Game 1 - Car Chase - Low Detail	42.0 fps
Game 1 - Car Chase - High Detail	17.3 fps
Game 2 - Dragothic - Low Detail	39.5 fps
Game 2 - Dragothic - High Detail	13.1 fps
Game 3 - Lobby - Low Detail	68.2 fps
Game 3 - Lobby - High Detail	32.9 fps
Fill Rate (Single-Texturing)	453.4 MTexels/s
Fill Rate (Multi-Texturing)	591.0 MTexels/s
High Polygon Count (8 Lights)	2.4 MTriangles/s
DISPLAY
Width	1024
Height	768
Depth	32 bit
Z-Buffering	24 bit
Buffering	Double
Refresh Rate	60 Hz
FSAA Mode	None
OPTIONS
Continuous Demo	No
RESULTS
3DMark Score	2557
Game 1 - Car Chase - Low Detail	40.6 fps
Game 1 - Car Chase - High Detail	16.7 fps
Game 2 - Dragothic - Low Detail	39.1 fps
Game 2 - Dragothic - High Detail	12.9 fps
Game 3 - Lobby - Low Detail	58.9 fps
Game 3 - Lobby - High Detail	29.0 fps
Pics:
