First post, by sebaz_ri
I want to know the jumper settings for this mobo, plus if it supports the Cyrix 5x86
AMI BIOS string:
41-C103-428027-00101111-101094-ALI87/89-U
Mobo specs:
2x 72-pin SIMM
Socket 3
ALI M1489 chipset
LGS Prime 3B IDE controller
Number found in the back of the mobo:
PCI486
V1-HJ2
071195
Reply 4 of 13, by sebaz_ri
I found one that matches very well but there are some differences
    71.67 KiB
    PCChips M918
Reply 5 of 13, by Tetrium
Iirc there were only a few 486 boards on th99 that had 2 SIMM slots
My retro rigs (old topic)
Report spammers here!
Reply 6 of 13, by dirkmirk
That chipset can support the 5x86, this is the board I have unfortunately no bios chip http://stason.org/TULARC/pc/motherboards/A/AB … B4-REV-1-2.html
Reply 7 of 13, by DonutKing
I found the PB4 BIOS here: http://www.motherboards.org/mobot/bios/Abit/PB4/
If you buy some flash EPROM's that fit you might be able to hot flash it in a different board, or use uniflash and flash it in a network card with a boot ROM socket.
I've actually got a couple of flash EPROM's in the mail to attempt this with a couple of my own boards...
Reply 11 of 13, by dirkmirk
Sorry for hijacking the thread, how do I know what flash eprom to buy? IE number of pins, size of the chip, ive dont know anything about bios chips.=, and lastly where to buy
Reply 12 of 13, by DonutKing
Here's a thread I posted on the topic:
Am5x86 on UM8810P
I haven't recieved the chips yet but I'll update with the results when I do.
But without knowing what chip was in there before its hard to tell exactly.
My board had 27C010A BIOS chips, I ordered 28F010A replacements (which are flash programable unlike the old ones) with the same pin count.
Reply 13 of 13, by sebaz_ri
You can buy any 128k flash eeprom and use UNIFLASH for flashing; i've flashed 3 mobos with this program and no one was damaged, and if you have dead mobos maybe there is a flash eeprom in there, you need to perform 'hot-flash' to flash this mobo, if you need help, ask me
