First post, by Starlight
Hi im new to the forum, im not sure if im posting this in the right section.
But i bough a steelseries game controller to play Games on my netbook.
I downloaded the 3gc installation Nd i tried testing it first before playing.
looks like all the buttons were lighting up. but once i go to a ROM game.
it didnt work. idk what im ding wrong.. Im trying to play
AN SNES emulator.. I also have Emulator for N64, n gameboy advance.
would the Steelseries work for these emulators on my Netbook?
i need help setting it up.
what do I do?
thanks in advance.
Reply 1 of 10, by GXL750
Most emulators that support game pads require you alter the default options to make it use the game pad. Look around in the available dialogs in the emulator you're trying to use.
Reply 2 of 10, by Stull
My guess is that the SteelSeries 3GC uses Xinput (not DirectInput) and so input isn't detected by the emulator. What emulator are you using?
Reply 3 of 10, by Starlight
i have Project64, VisualboyAdvance, Znsesw, N Nestopia as emulators to play old games on my netbook. Im not sure of the input, i checked to see if it worked and when i test it the lights were glowing, but when i want to play a game it doesn't work on any of the emulators I have, I checked.
idk if it has to do with a setting, but if anyone knows who can take me to the right location of the setting to put I appreciate it
Reply 4 of 10, by GXL750
In ZSNES, when you first open the emulator, click the config button on the blue bar at the top then click Input in the drop down menu. From there, you can set up the controls.
Other emulators should have somewhat similar configuration dialogs. Look around in the menus and settings dialogs.
Reply 5 of 10, by Starlight
thanks gxl, im a try that, i was in the option section playing with the keyboard/control, Ill try n do what yu said, thanks if im still havin problems i'll post
Reply 6 of 10, by Wolf spider
There are some programs on the net that remap controller buttons to be keyboard keys allowing you to play with a controller even with games that don't support controllers.
Here's a link:
http://electracode.com/4/joy2key/JoyToKey%20E … h%20Version.htm
May not work but you can give it a try (it worked for my steelseries controller)
I think after you remap your controller you leave the app running on the desktop but you might be able to minimize it.
SPYWARE: junk coded by spies
TRASHWARE: Junk coded by oscar the grouch
FREEWARE: Junk coded by people not in jail
WARIOWARE: awesome junk coded by Wario
Reply 7 of 10, by Mau1wurf1977
No need to remap keyboard keys. A standard USB gamepad or joypad is all you need. I use BSNES (more accurate vs. ZSNES), Mame, Fusion, WinVice and they all work with USB input devices.
My YouTube channel
Reply 8 of 10, by Wolf spider
true, but it could help with other games and things as well (like oblivion which doesn't let you look around with the controller)
Reply 9 of 10, by leileilol
So do I, but netbooks aren't exactly known for having multi-core 3GHz CPUs...
